Question about Garmin StreetPilot c340 GPS Receiver
Garmin 660 broken screen
The suction cup failed. Device seems fuction but input is impossible due to
broken glass. Garmin wants $250 to fix a piece of broken glass. I can by
a certified used one for $299. That makes my unit worth $44. Can I get the glass and fix it myself?
  • 1 more comment
  • dcooper333 Jul 07, 2008
    I appreciate advice, but the screen is still working, the picture is perfect. When I press
    the initial "I agree" the screen procedes to the next step and displays the appropriate
    choices. From there on, the broken glass does not flex sufficiently to trigger input.
    I would like to await more suggestions.
    I would like to await more suggestions. But I
    will peruse the garmin repair site again to see
    if I can obtain this $2 part for less than $250.
    Great Job! Your answer led me to Ebay seller nuvi2007. Also the correct name for the part I needed (the clear glass that covers the LCD)is "touch screen digitizer." It is sold as a kit with tools and instructions.
  • Garmin Master
  • 13,433 Answers
So the top part of the lcd screen is cracked the touchscreen is still working ok?
You may have to replace the whole screen, if you feel that you are up to the task, you have to take the garmin apart, remove the lcd screen from the mainboard, then you need to take the lcd screen apart and replace the glass, thats all you might have todo, im not sure how the screen is actually build in your garmin.
Posted on Jul 07, 2008
  • 19,396 Answers
    Genius:
  • 1,142 Answers
Its the LCD glass which has gone bad you cannot change it yourself,
  • Maanita Chadha
    Maanita Chadha Jul 07, 2008
    Its Liquid crystal display (lcd) glass which you might get it from some repair shop if they have one in spare or else the company Garmin itself keeps the spare parts to repair those units are under warranty,
Garmin nuvi 660 froze up.
This is not caused by an update. Please check your unit's serial # to see if it starts with a "12P", "14V" or "143". If so, these units have a specific touchscreen that can fail even without physical damage to the glass or screen. The only way to resolve it is to replace the touchscreen & glass. You will not lose any of your data. The unit is not frozen and you can verify it by quickly pressing the on/off button. If you hear a beep, it's not locked up. You touchscreen has failed and won't accept any input. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Apr 10, 2010 | Garmin Nuvi 660 GPS Receiver
Can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
Mar 24, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 660 "Display unit " won't seperate from mount
If you have the suction cup holder in the middle of the bottom of holder there is a tab there... hold gps while thump underneath and press thump upward to release and pull out unit
Mar 13, 2010 | Garmin Nuvi 660 GPS Receiver
Cracked screen
The only way to repair it is to send it to Garmin for service. They recently told me the flat rate to repair my streetpilot 550c was $250. (!)
Jan 03, 2009 | Garmin Nuvi 660 GPS Receiver
Unit will not hold suction (c330)
put a little spit on the rubber suction cup than install on window i had the same problem
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
The earplug/headset input on my Garmin Nuvi 660 is broken.
Interesting problem but I have repaired this problem before. This is not going to be something you can fix yourself.....believe me... I have 30 years of experience in Electronics.
The headphone jack either has to be resoldered or replaced. When its loose, in most cases the pins of the jack are broken and/or the printed circuit board tracks have been torn off the board. The jack is a surface mount part.
A new jack must be installed but there is no way to solder in a new jack because the printed circuit board tracks are gone. The new jack must be installed with epoxy to the board and new wires have to be soldered from the printed circuit board to the jack.
There's around 2 hrs worth of work involved in this repair.
- Jim
SHARCNET-USA
Dec 02, 2008 | Garmin Nuvi 660 GPS Receiver
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin street pilot c330 - Suction cup lever broken
If you cannot un-assemble the suction cup assembly to fix it, then you would have to replace it. If it is under warranty, demand an exchange.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Mar 03, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
183 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
