Question about Garmin eTrex Legend GPS Receiver
Display on etrex Legend is dim
I have two, identical, etrex Legends. The display on one has become very dim, almost faded looking, making it very difficult to read. The display on the other etrex is very dark and easy to read. Both are roughly the same age, with the same amount of use. Any idea what the problem is?
Have you tried Main Manu / Setup / Display and then adjusting the contrast?
Posted on Jul 18, 2008
  • 3 Answers
You can adjust the display in your GPS setup menu. Looking for eTrek for spares if you have one to spare.
Posted on Jul 22, 2008
Garmin etrex 12 channel gps, screen very dim contrast with new batteries
For the Etrex Legend you can click the page (top right hand) button till you get the main menu, select setup then display. Point the click stick down until the bar on the left is highlighted. You can then move the bar up and down until you get the contrast you want. You could first try clicking the square near the top right and selecting restore defaults, but if the default contrast is not to your liking then you can change it using the bar.
It is probably similar on related models such as the Venture or Vista, if in doubt check your manual.
Dec 30, 2010 | Garmin eTrex Legend GPS Receiver
The backlight on garmin legend is dim - how do i brighten it
When the unit is on, press the bottom right side button on the GPS unit. A slider will appear to increase brightness, use your toggle to move the slider up.
Hope this solves your problem. If so, please come back and tell us, and rate our solution. Thank you.
Dec 20, 2009 | Garmin eTrex Legend GPS Receiver
My owner's manual and reference guide was "drowned" while fishing. I need another one for my Garmin eTrex Legend personal navigator.
hi,
This should be the manual your looking for:
Garmin eTrex Legend Manual
This is a pdf file so you will need adobe or foxit to read it, I;m sure that most pc's come with adobe on them though.
I hope that helps..
Mike
Sep 01, 2009 | Garmin eTrex Legend GPS Receiver
Etrex Legend locks up, screen blank except vertical line
Is the unit being bumped during use? If not, sounds like a call to Garmin tech support is in the works. My thought is that it's something defective inside your unit.
Jun 21, 2009 | Garmin eTrex Legend Cx GPS Receiver
GPSr shuts off
Firmware needs to be upgraded on these units because the atellites are changing every so often so does the programming in these units, check to see if there is a firmware upgrade to fix these problems, the line in the middle of the screen is because it either hung during the process or the units lcd is going bad.
Apr 22, 2009 | Garmin eTrex Legend GPS Receiver
ETREX LEGEND HAS 1 VERTICAL LINE ON SCREEN AND WONT SHUT OFF UNLESS YOU PULL BATTERYS
Have you updated your unit's software from the Garmin site? There was a new satellite launched in 2008 which has been causing problems, and the new update fixes this.
Mar 03, 2009 | Garmin eTrex Legend GPS Receiver
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
Screen appears to freeze up
Try updating the unit software. A new satellite was launched this year and has been causing problems. The updates from Garmin fix it. Disable the WAAS in the meantime and see if that solves the problem in the meantime.
Dec 06, 2008 | Garmin eTrex Legend GPS Receiver
Etrex legend
Have you checked if you have selected the correct Datum for your location, usually is WGS84
Apr 18, 2008 | Garmin eTrex Legend GPS Receiver
A dark screen might be the result of a poorly adjusted display contrast. This can be altered by accessing the Setup menu and selecting Display.
Feb 01, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
319 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
