Question about Ricoh Office Equipment & Supplies
My Ricoh FT5632 displays this message E-5 and doesnt allow me to do anything, please healp
3 Suggested Answers
  • 42 Answers
SOURCE: Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
Posted on Jul 04, 2008
  • 389 Answers
SOURCE: I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Posted on Sep 13, 2009
I have 5 machines Ricoh aficio 3235c showing a massage loading toner and then black toner is empty Althought the toner is full????
This is one possibility, but there are other solutions if this don't work.
The black toner is not set message is displayed. The black toner is not set message is displayed even though the black toner is set.
There is a problem with the BCU lift. The communication with the ID chip is faulty.
Update the BCU software version to the latest version.
Apr 01, 2017 | Ricoh Aficio Office Equipment & Supplies
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
When we turn on the power we are getting an error message "Functional problem within the Copier. Please call service and report the service code SC552. Ricoh Copier Model MP5001
Solution Reset (machine was not working for 2 - 3 month):
C button (yellow) + on keyboard: 107 + C-button (orange + large) long press
Then, go to the menu
Mode 5 enter
here below 810: SC Reset
Unfortunately, there is no OK
keyboard: 0 or 1 (probably 1) choosed and press #
it displays a confirmation message: run as service - etc.
Switch off the machine
Error: reset
(on some devices without a reset command: open flap + off)
Jan 29, 2011 | Ricoh Computers & Internet
We are getting the following error message when we turn on power. "Functional problem within the Copier. Please call service and report the service code SC552". Ricoh Copier Model MP5001
That is a fuser under heat condition.
Try this. May take a couple of times to clear.
Press the in this order. Clear all ( yellow button) then press 107, then press and hold the red stop button until the screen changes to show a screen that says. Copy SP ,,, Print SP etc.
Press Copy SP, when the screen changes, shut the main power off then back on.
If that doesnt work then repeat the clear all 107 stop and enter Copy SP again, Then scroll down to the 5 tab. press it, scroll to 810 and preform that reset.
If that doesnt fix the problem, then most likely the thermistors and over heat thermostats will need to be replaced.
Jan 29, 2011 | Ricoh Office Equipment & Supplies
Have a Ricoh GX5050 s and have a Err990. The printer has leass than 500 copies on it and has been idle for a few months. Any suggesstions Please ?
That is a network or connection problem Has anything changed set up wise ckeck that you have the right driver installed.and check that the physicsl connection is correct
Jan 28, 2011 | Ricoh Aficio GX5050 GelSprinter InkJet
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there...
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
Oct 06, 2009 | Ricoh Aficio AP410N Laser Printer
Jul 03, 2008 | Ricoh Aficio 1035 Copier
93 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
