Question about Toshiba Satellite M30X Notebook
PXE-EX61: Media test failure. It is only I get at start up my laptop
SOURCE:
dugiehowsa
  • 114 Answers
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Posted on Oct 10, 2006
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF  found no fault on the HDD. (full test took 45minutes)    Give it a try.  I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives.  Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck.
Bryan
Posted on Oct 21, 2007
ohms
  • 1879 Answers
SOURCE: PXE-E61: Media test failure, check cable
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Posted on Aug 31, 2008
SOURCE: PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Posted on Nov 01, 2008
ajx13
  • 110 Answers
SOURCE: my mini dell inspiration laptop sends me an error
This error comes up if the computer is not able to detect the hard drive. Power off the computer. Power it back on and tap the number 2 key 4 - 5 times at the Dell logo screen. This will take you to the system setp screen. Check if you see any thing listed next to solid state drive. If you dont see any thing try reseating the hard drive. Here are the steps to reseat the hard drive.. If you see an entry next to the solid state drive. You'll need to reinstall windows on the computer. If you have been shipped XP you will need an external CD drive to reinstall windows. If the system was sen with ubantu try to download it to a usb drive and boot off it.
Rate if useful.
Posted on Aug 08, 2009
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Aug 31, 2008 | Acer Aspire 3680 Laptop
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite M30X Notebook Logo
384 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
