Question about Whirlpool LSR7333 Top Load Washer
Whirlpool LXR6232EQ0 Drain Question
I have the model listed above. Right now the washing machine will go through the cycle and stop once it gets to the drain. I manually drained the machine and then flipped it over. I pulled off the pump to see if something might be clogged in it and nothing was. Then with the pump off I turned the machine on to see if it would work. NOTHING. Do you think the problem is the motor and it needs to be replaced?
    Genius:
  • 1,198 Answers
See the reply about the lid switch, it's usually the first thing to go on a washer.
Posted on Jul 29, 2008
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Specs for drain pump model LXR6232EQ0
It wont pump that high, well it will BUT when the pump stops it will drain all the water back into the machine or it will give you an error that it is not able to drain fast enough. The only thing that might work it the installation of a check valve.
Jan 30, 2014 | Whirlpool Washing Machines
Wont drain in automatic cycles
maybe is necesary to set the drain operation in the automatic cycle,like you can set the temperature of the wather ,the time to prewashing and so on.
Dec 26, 2013 | Whirlpool Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
I have a Whirlpool Washer (Model: LXR6232EQ0). It will start washing & then stop. After pulling the timer out & pushing back in, the washer resumes operation. This happen 3-4 times per cycle. ...
You are correct in assuming that the timer is going out. It is fairly easy to replace, you simply take the upper back part off of the washer and remove the screws that hold the timer in place and reinstall the new one.
Mar 02, 2011 | Whirlpool Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
I have an whirpool (LXR6232EQ0) washer. The agitator does not move after the water fills the tank. Also on the rinse cycle, the agitator does not spin. Any idea would be appreciated...
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 17, 2009 | Whirlpool LXR6432JQ Top Load Washer
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight...
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight tinkle once in a while. Could it be the motor coupling or do you think it is the clutch. The agitator doesn't spin at all. does it have a belt?
Mar 17, 2009 | Whirlpool Washing Machines
Zanussi washing machine
Check your filters first, then the pump. Refer to your manual; or click troubleshooting above.............sure would get some tips.
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR7333 Top Load Washer Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal De
