Question about Maytag Washing Machines
Maytag SAV4655EWW washer doesn't drain
In the rinsing/spinning cycle, the machine stopped. It wouldn't start or drain or do anything on any cycles. I removed the clothes and then manually scooped out the water. When it was almost empty, then the spin function would work. I restarted the load and encountered the same problem and again had to drain most of it for the spinning to occur.
  • Anonymous Mar 23, 2014
    I started a load of clothes in my washer ,and it ran the cycle until it got to spin it drained some water but did not spin out , I discovered im missing a sock. where could this sock be stuck, and could you show me a diagram please
  • Anonymous Mar 25, 2014
    CLOTHES SOAKED, WATER ON FLOOR AND MACHINE NOT DRAINING WATER
    President:
  • 1,462 Answers
The filter is blocked or a foreign object in pump impellor
Posted on Jul 07, 2008
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My machine stops working after the rinse cycle and won't go into the spin cycle. The water stays in the tub and will not drain. I have unplugged and replugged the machine just to make sure. I wanted to see...
It sounds like the Drain pump may have stopped working. After the rinse cycle, the machine should drain the water and start spinning. The Drain Pump should be at the bottom of the machine.
Feb 22, 2011 | Roper RAS6233KQ Top Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Washing Machines Logo
342 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
