Question about Okia / 450-Watt / ATX / 80mm Fan / 20/24-Pin / Power Supply (OKIA450ATX) Power Supply
Busted component hi, i have a psu with model LC-B500E and pcb model Y-500ATX ver:A-1. a componet was burned and i wanted to replace it. ca u help me find a schematic diagram so that i can know the value of the component so i could replace it. i think it was mark as L9 n the PCB. thanks a lot.
    Novelist:
    Champion:
  • 254 Answers
Getting a schematic is rather doubtful. You might be able to get a general idea of the circuit from somewhere on the 'net.
Was the power supply dead?
ATX style power supplies have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard.
If the component failure is in this section, this standby voltage will be missing or incorrect, and the computer will be dead- won't power on at all.
I've seen a number of catastrophic failures in this standby circuit, and repair isn't suggested or economically feasible, especially as some parts often poof beyond identification.
When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Posted on Jul 07, 2008
Had 32" luxor tv 3 years. Now when turning it on just get flashing power light. used to turn on after few blinks but not now.
you need to take it to a TV shop
or... what i do is look on EBAY for a replacement PSU panel
for the exact model number
check the PSU pcb inside the set for its part number to help match it
you give too little info for me to help further
you need make model and exact problem
its a psu issue for sure.....
some electrolytic capacitors are dried up as its aged
this is the usual cause
Dec 04, 2014 | Luxor Televison & Video
Replace part on hard disk controller board
i have the same issue with my hdd. same drive only the 160gb one. you may be able to buy a replacement PCB board. check out:
hddzone.com
Jan 05, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Acer X223W power supply
the voltage inverters are the small transformers attached to a small pcb, that is connected to the backlight inverter (cold cathode).
Just in case replacing the capacitors did not work, the second thing to do is to check the backlight inverter. If there is busted light, replace this one too..the last thing to check is the high voltage ballast transformer... if one of these is burnt, it is enough to affect the stability of your supply current. It can also result to a dark portion on your screen or worst , could result to a total black screen..
If you can replace this transformer with the same value, please do so.
If this is a help to you.. please rate this solution...thanks.
May 28, 2010 | Acer 22" X223w LCD Monitor
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
the needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Compaq
Without a visual inspection it sounds like the PSU is damaged, it is possible that the standby power is reaching the motherboard but the main circut is bust. i would replace the PSU with one of the same watt rating.
Be aware that incorrectly installing a power supply can cause damage to other componets or yourself. If in doubt see professional advice
Jun 20, 2008 | Compaq Computers & Internet
Maxtor hard drive needs a chip replacing
Unless you can find the matching chip and are good at soldering these small parts, it can be replaced.
Typically, I would suggest looking for busted harddisks (of the same model) and if their board was still good, just do a direct swap. I did this for a Fireball model HDisk.
Or if their board is busted, you can get the chip from them and, like I said earlier regarding soldering, solder it onto your Hard disks. This is considering that the only part busted was this chip.
Jan 21, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
VIZIO RP56 Rear Projection
Check the component jacks where they connect to the pcb for cracked solder joints and resolder to board.
Jun 27, 2007 | V, Inc. VIZIO RP56 Rear Projection...
Okia / 450-Watt / ATX / 80mm Fan / 20/24-Pin / Power Supply (OKIA450ATX) Power Supply Logo
354 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
