Question about Maytag SkyBox MBV1976A Beverage Dispenser
Does not cool anymore
Sounds like compressor comes on for about 10 seconds and then goes off. Repeats after a few minutes. Used to work fine but suddenly does not cool at all. midnyt@comcast.net
  • 770 Answers
Check your email
Posted on Jul 08, 2008
    Problem Solver:
  • 7 Answers
I recently posted a possible solution to your problem in another similar thread (I put more detail in that post)...it sounds like the starter relay on the compressor has gone bad (if you take it off and you shake and hear pieces, that is your sign it is bad) - replace with Whirlpool kit 4387535.
Compressor only stays running for about 10 seconds and kicks off. Will not turn on for about 3 minutes and continuously repeats this cycle.
Sounds like the compressor has siezed. Switch off to cool for 3 h.ours and try to restart. If it has a start capacitor, repace it
Jul 14, 2015 | Refrigerators
Maytag MSD2351HEB sidebyside occasionaly goe thru frequent cycling buzz. Last for a couple of seconds, then repeats a few minutes later. sounds like a solenoid click when going off.
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Aug 01, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Fridge has a buzzing sound
Sounds of the start relay is struggling to get the compressor started. In most cases the start components will need replaced to prevent further damage to compressor and loss of food storage. In these cases I always test the compressor windings to insure the compressor winding are not breaking down. I will not be able to tell you the parts you will need but it is a sure deal, work will need to be done in this area. I will need your model number to assist in parts. I will give you a helpful link on a compressor windings test. I reccomend that someone do the work soon, Thanks, Sea Breeze
Feb 23, 2010 | Maytag Refrigerators
Compressor runs only a few seconds then clicks off
The compressor is going bad, check your owners manual for warranty information or look here http://b2b.frigidaire.com/support/manuals.asp if you cant find the manual. Some units have up to 7 years on the sealed system (the compressor, cooling coils, and hot coils).
Jan 30, 2010 | Refrigerators
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
96 Honda Accord LX 4 cyl - ac goes on/off every 15 seconds
when the compressor cycles fast that usually means that its low on freon.use approved gauges to get good pressure readings.
May 05, 2009 | 2004 Honda Accord
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
171 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
