Question about Garmin Nuvi 760 Handheld GPS Receiver
Installing on dashboard
Hi -- cant find manual and am not sure what to do with the circle/disk in the box --it is separate from the holder... in other words, howdo i put this thing on my dashboard.. i mean the holder for the nuvi. thanks
Download the owner's manual here:
https://buy.garmin.com/shop/store/manual.jsp?product=010-00657-10&cID=134&pID=10624
Posted on Jul 14, 2008
Why would the radio display light be out? also need a clear ez to read fuse box display for inside fuse box
Because the bulb(s) are blown - is one guess. Most factory radio lighting is tied to the dashboard lights. You can tell for sure if the radio lighting used to dim when you adjust the dashboard lighting intensity. If they were separate, then it could be a problem with a connection at the back of the radio or internal.
Nov 24, 2015 | Cars & Trucks
Download a recovery disk for imac os x 10.5
Hi,can't remember if I have answered, any way try this you will have to do a complete reload. Date will be lost.
switch off hold down command+R then switch on holding down afore mentioned, hopefully this will start a complete install.
The other if not sure.... Search engine and type in iMac complete re- install, lots of info, if you not able access,then try the method mentioned..
Mar 05, 2013 | Apple iMac G5 Desktop
2oo2 325i dashboard liht came on it is yellow circle around a triangle and something in the middle of triangle i cant see, what is this light for?
Traction control is off, can be manually over-ridden (or turned back on) by pressing a button on center console.
Aug 03, 2010 | 2003 BMW 325
How to remove spark plug wires from the distributor on a 1992 camry 3.0l 6 cyl they have some sort of cover for each wire
Please don't forget to rate!
  1. Disconnect the negative battery cable.
  2. Label and disconnect the wires from each spark plug one at a time.
  3. Remove the spark plug wires from the distributor cap. On some models you may need to use a flat bladed tool to lift up the lock claw and disconnect the holder from the cap. Separate the wires at the grommet.
Make sure to remove the spark plug wires from the boot end and NOT from the wire itself
Lift up the lock claw and disconnect the holder from the cap
WARNING Do NOT pull on the plug wires to remove them, this may damage the conductor inside.
  1. Pull the plug wires from the retaining clamps.
To install:
  1. Attach the holder and grommet portion to the distributor cap. Make sure that the holder is installed correctly to the grommet and cap.
Align the spline of the cap with the spline groove of the holder
Make sure the holder is correctly installed to the grommet
  1. Check that the lock claw of the holder is engaged by lightly pulling on the holder.
  2. On the center cord, insert the grommet and holder together.
  3. Secure the wires with the clamps.
Mar 06, 2010 | 1992 Toyota Camry V6
Where is the fuse box for Suzuki Grand Vitara. Dated on the registration plate (driver's side door) Dec 2001. Hint, IT'S NOT UNDER THE DRIVER'S DASHBOARD AS THE MANUAL INDICATED
Hi I'm litoshop there's one under the hood in the right side near the shock absorber tower and under the dash you find the relay block and some vitara have a fuse box in the lower left side behind the coin holder pull the coin holder and behind that you'll find a fuse box good luck if this information has been useful please let us know thank you.
Aug 29, 2009 | Suzuki Vitara Cars & Trucks
The man computer will not record sensor or catalytic activity, Reads "not ready".Want to replace computer, where is it? under dash in side kick panels?
1 Remove the cover of the main fuse box on the side of the dashboard. 2 Remove the knee shield above the pedal assembly. 3 Lift out the air duct to facilitate access to the relay holder behind it. 4 Remove the screw securing the relay holder and press the holder down.
The Integrated Central Electronics (ICE) module is mounted above the relay holder. 5 Install in reverse order.
Aug 18, 2009 | 1996 Saab 900
Dashboard warning light as a circle with wavy lines through it
This is probably the coolant level sensor indicator for the antifreeze reservoir.
Sep 09, 2017 | 2002 Dodge Neon
Garmin Nuvi 760 Handheld GPS Receiver Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
