Question about Maytag SkyBox MBV1976A Beverage Dispenser
GETS COLD IN 4 HRS
Mine gets cold in 12 hrs runs for a day then stops getting cold ,unplug it for a day samething ,i can hear every thing running ,i see theres alot of relay problems could this be the issue
  • 770 Answers
Sure could be what is your email i will send you the manual
Posted on Jul 08, 2008
106.74259400 not cold enough
check to see if the fan in the freezer section is running, replace the fan motor if not running. if running, has the back wall of freezer got frost on it. if so turn off for 3 to 4 hrs with door open to defrost. if the frost returns in 2 or 3 days, call for service.
Jan 05, 2012 | Kenmore Refrigerators
My pool water has turned green in 2 days. I have an Intex pool with a saltwater system. How do I get it back to normal? I am new to the pool thing so you may need to put the awnser in laymans terms.
As long as you have the correct amount of salt and the electrolytic cell (The thing that makes the chlorine) , run the pump at 12 hrs with the chlorinatior at 10 to 11 hrs in between those 12 hrs for one full week and you will see results. Also, vacuum and clean your pool now before you start the 12 hrs cycles.
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Hi i got a Electrolux ER7826B and other day i defosted it and now it dont seem to be getting cold since turned it bck on its been bck on for 12 hrs and still not cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Electrolux ER7826B Bottom Freezer...
It stops getting cold and freezer warms up. then within 24 hrs, its starts working fine again
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 13, 2010 | Refrigerators
I have a Whirlpool refrigerator, Model # ET18NKXFW0 1, Serial # EG5130791. It has working fine for 12 yrs. I recently moved it from one location to another in the back of a pickup on its side. As soon as...
Refrigerators should never be plugged into a GFI due to the start up amps that it draws on start up. With other items on the same circuit it is too much of a load. Refrigerator need to be on there own individual circuit to keep this from happening and not a GFI. Hope this helped.
Feb 02, 2010 | Refrigerators
FRIDGE/FREEZER ON THE BLITZ?
Try removing everything out of your fridge, switch it off and open all doors for 12 hrs. Then close doors and switch it on for another 24 hrs before putting in you stuff. most likely the evaporator is iced up, you need to defrost if fully.
May 04, 2009 | Refrigerators
GE Side by Side Not cooling/freezing
sounds like defrost problem. remove back lower panel in freezer. defrost all ice on coils, this will fix problem temporaily. I`m looking for the tech sheet to test system.
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
I have a cold freezer/warm fridge problem
Hi, Yes, They are the same thing. Can you hear the fan motor running in the freezer? If not it probably needs replaced. Some units shut the fan off by a door switch. If its not running when the door is closed, it could be the door switch. If the fan is ok, make sure the thermostat is set right. Sometimes something in the frige gets bumped against it and it will get moved. NOTE: Allow aprox 12-24 hours for changes in thermostat settings to take full effect. If this all checks out ok I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer. Hope this helps. kstfas
Sep 15, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
