Sony KP53XBR45 no picture and sound/problem is high-volt shutdown immediately
  • kadesh Jul 07, 2008
    135 volt was ok immediately then goe away,
    please respond asap,
    thank you
  • 70 Answers
Check the soft start system within the ower supply. also check se 135 and the electros .
Posted on Jul 07, 2008
  • john clyde Jul 09, 2008
    ok. now disconnect the collector of the horizontal out transistor.
    now try turning it on and check to see if the voltage remains.
    if so you have a crook flyback tranny.
    also before changing the tranny remove the vertical ic and attempt to start it.
    if it does start , it will come on with a line across the middle and normal sound.
Sony trinitron standby light blinks 7 times. no picture. light continues to flash. tried hard reset. no picture. model sony wega kv-36hs510.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a sony rear projection tv that went on then off rite a way the red lite blinked 7 times i took the front panel off and adjusted the 6 color tuners and the tv stays on but there is a blue 3d look ...
7 blinks means High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 08, 2011 | Sony KP-51WS500 51" Rear Projection...
When i turn on tv it blinks 7 times no raster and on sound you can hear the high voltage goes up to the picture tube and then stop
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You have a power regulator fault and it shuts down to reduce the X radiation from the tube.
Check the 135Volt line!
Dec 24, 2010 | Sony Televison & Video
Sony 40" tv kv-40xbr800 pwr/stanby lite blinks 7 times no power or sound
hello shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Dec 27, 2009 | Televison & Video
It wont turn on it blinks 7 times can i fix this
Hi there.
In sony tv`s the seven blinks code(sony error codes)usually indicates a high voltage shutdown(t.v has exceeded 33k volts). That is often caused by the power supply regulation and/or horizontal circuit fault.
Hope this help Merry Christmas
Dec 19, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KP53XBR45 Customer was watching it and the picture just whent out but still had sound. Now when press power button the LED light flashes 7-times and won't turn on. Any suggestions? Thanks, Alltech...
Are you getting sound? If not, then your power supply is faulty. If you sound but no picture, then an IC or STK capacitors are faulty depending on what type of tv it is.
Sep 23, 2009 | Sony KP-53XBR45 53" Rear Projection...
1999 sony trinitron color tv -no picture-no sound.
Hello c_car,
What is happening is that the Shutdown Circuit is turning the TV off due to excessive current flow. The excessive current flow is most likely the result of a problem in the HV (High Voltage) section of your TV. This could mean that the Horizontal Output Transistor or the Integrated High Voltage Transformer has malfunctioned (developed a short circuit). I would advise that you let a qualified TV technician work on the set due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | Televison & Video
I have the sony trintron wega 32 hs 500
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Bill
Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36HS20
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jan 28, 2008 | Sony KV-35S45 35" TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Electro Med Services...
