Question about Saeco Incanto Classic Espresso Machine
Water leaking out of the machine when you use the steamer
  • 515 Answers
The steam valve is leaking on your machine, if you open the door you can see the water drip from the right upper corner.
Posted on Jul 10, 2008
Water is coming through steamer instead of espresso spout
There is something prob scale keeping the steam valve open it needs to be disassembled cleaned and inspected , they can wear out and need replacement
Aug 18, 2014 | Saeco 00034 Incanto Sirius Super Automatic...
Water leaks around the steamer
May be. If you get the machine upside down (switched off) you will find a hole near the steam knob which allows access to a screw. Turn this screw with a flat bladed screwdriver and the knob will come off. There is a gasket (washer) near the end of this know which is the seal. I don't know where you get the seal, but try finding a rubber seal in a gasket kit. This may be the problem.
Nov 25, 2013 | FrancisFrancis! X1 - Stainless Steel...
Steamer does not work
Possible problems:
- no water
- heating element burned out
- switch defective
- leak in steamer system
If it's out of warranty you'll have to open open it up and test with a multimeter.
May 06, 2012 | KitchenAid KCM511 Coffee Maker
Lg steam washer 2yo 3 yrs old . Refresh cycle produces bribble of water rather than steam and leaves clothes wet
The steamer unit may be overfilling. Check the water valve and see if it leaking. If it's ok, you will need to replace the steamer unit. Good luck
Jun 17, 2011 | LG F1402FDS6 Front Load Washer
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Leaking
You need to contact Delonghi and order a part. This is the steam/water outlet assembly. This part includes an electronic solenoid which controls the water and steam output. I have had this problem 3 times. You may find the steam/ water is very loose when you try to wobble it sideways. This is the indication as to what is the problem, (as mentioned above).
Jan 27, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Steamer backed up water pours out under machine
On the cva 610 and 615 the steamer valve gasket tends to wear. Causing the unit to leak. Your best bet it to remove the steamer valve, Looking at the knob stem there is a plastic pin you can press to remove the stem from the valve. Once removed there's a small o-ring on the stem. ( That's where it's leaking from ) replace the o-ring and the stem to be safe. Also take a look at the micro sw to make sure it doen't have any corrosion if so replace it. If not your on the road to recovery. Good luck
Dec 29, 2008 | Miele CVA610
Dualit espresso machine
lost my instructions for descaling my delonghi espresso machine
May 15, 2008 | Coffee Makers & Espresso Machines
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Saeco Incanto Classic Espresso Machine Logo
232 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
