Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148GTL Missing TX Modulation
I have a Cobra 148GTL. TX light changes and carrier is present but there is no modulation. Checked microphone appears to be working. Replaced Capacitor C176 with a 16v 47uF identical capacitor (in the audio amp stage). Problem affects both SSB and AM. Receive works great. Carrier activates other radio just can't here voice.
  • Anonymous Jul 15, 2008
    Hooked this up to a watt meter, no SSB out put wattage.
  • Mark Oct 04, 2012
    possible dead 2sa1012 AM regulator. check & replace with good PNP. TIP42c seems ok
Check voltage regulator
Posted on Sep 15, 2008
    Problem Solver:
  • 9 Answers
The problem is most likely the audio ic . open the radio and see if the diode 44 is blown or see if you see anything that looks like it got hot around the plug area. if not contact me and i will buy it. is it an old or new 148 gtl.Read more
Posted on Dec 06, 2008
My radio 148gtl d has low modulation
The Modulation adjustment is VR5, or you can cut D9, though I do not recommend completely disabling the AMC circuit. If VR5 does not have enough range, lift the banded end of D9 & solder a 1K-ohm resistor in series with the diode, then adjust for 100% modulation or to where the AMC circuit just starts to limit modulation.
Mar 04, 2014 | Cobra 148GTL AM/Single Sideband CB Radio -...
Where can I find a new replacement modulation transformer for a cobra 29 ltd classic?
simple,just chech the input resistance and out put...they should have even small resistance always example .5ohms .3 ohms it counts...
Feb 01, 2014 | Cobra 29 LTD CB Radio
My cobra 148gtl has low modulation on sideband. What can I do to correct this.
Check the Mic. Sideband you can talk up. ie the louder you are the more mod.
Jan 24, 2014 | Cobra 148GTL AM/Single Sideband CB Radio -...
My Cobra 29 LX receives including the weather but can't transmit
If the relay contacts are closing. You may have blown the output transistor, however a broken wire in the microphone can also create the symptoms you describe. .
you can check by using a #47 light bulb soldered to a PL259 connector as a dummy load. If it lights, the carrier is present, but you may not have voice modulation which will show as differences in light intensity as you speak. If no modulation, the microphone is the first thing to look at.
The relay contacts may also be very pitted or corroded and not achieving continuity.
Feb 17, 2012 | Cobra 29 LTD CB Radio
COBRA 21 GTL NO MODULATION NO RX. BUT IT WILL TX AT 3 WHATTS.I HAVE TRIED 3 DIFFERENT.MIC ON THIS RADIO CAN YOU HELP ME
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Jul 30, 2010 | Radio Communications
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a cobra 148gtl that has 26 meg and high
VR10,,tuneL37,L38 you can remove TR24 it's for
modulation,but it may over modulat if removed.
that will get you started.
Aug 27, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
No modulation
Hello Rob55spiral, Most common malfunction in no modulation is the microphone. Swap out with a known working mic. #1 If problem is corrected, aquire a DVM and repair the broken cable connection in your microphone. #2 If still no modulation you have an internal componet malfunction. Please inform me of results.
Jun 27, 2008 | SI-TEX Radio Communications
Cobra 148gtl
i am having this trouble as well. The ics was my thought too, but I think it is in the modulation circuit somewhere. another article i read said to check this. "Look for the collector of TR-23, you should read about 4.5 V with a dead key. If you find that this voltage is not present, check on the opposite side of R-120 for 6.5V. Most likely this voltage will not be present; if this is the case, C18 has shorted and needs to be replaced. This is a 330uf, 10V electrolytic capacitor beside L31. To prevent "future" problems, replace with a 16V unit." As of yet, i havent gotten that far. note this is from the cobra 2000, but they are very much alike. you might cross check the resistor capacitor numbers though. btw, isnt the mb3756 the pll ic?
Jan 28, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
573 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
