Question about Garmin nuvi 350 GPS Receiver
Power Switch The Power Switch turns the unit on but only if you press the power button supper hard. the same as when you need to turn it off. can you help .
  • Garmin Master
  • 2,130 Answers
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and the repairs I make prevent this from happening again.
If you would like for me to reasonably repair your GPS, please email me at KS3R at sharc dot net.
- Jim
Posted on Jul 10, 2008
The power switch is not turning the computer on.
switch problem / motherboard problem / smps
1 change power switch
2 check smps
3 mother board supper io check
remove power switch and short two lege
Feb 08, 2011 | Acer Aspire AX1800U9002 (PTSBW02001) PC...
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
Dell Axim X50 PDA won't turn on
try a hard reset
Dell Axim x50 / x50v / x51 / x51v:
Make sure the device is on before performing hard reset. To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-3 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button. To cancel press the Mail button.
IT may be that the mainboard is faulty and would need to be replaced.
Aug 03, 2008 | Computers & Internet
How do you reset to stock settings?
1. Turn of the unit using power switch (not standby button).
2. While pressing speaker1 and speaker2 butons, turn on power by power switch
3. Display flashes, release the speaker buttons, unit is reseted.
Nov 04, 2010 | Denon AVR-1908
How do you turn it on
The power switch is at the bottom of the unit. However you must follow this combination to get the unit to power up
To power the player on, set the power switch to the ON position, then press and hold the PLAY button for 5 seconds
To power the player off - first press and hold the PLAY button for 5 seconds, then set the power switch to the OFF position.
Hope this helps. Thanks for using FixYa.
Dec 30, 2009 | Mach Speed Trio V430 MP3 Player
Switch printer on,just get grinding noise on right hand
try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Need to know how to do a hard reset on the unit-lowrance533
try this ,
1.) turn off unit
2.) press and hold pages key
3.) press and hold power key
4.) release both buttons when the USA map appears
was for the 5300 searies , hope it helps ya.
Dec 25, 2008 | Lowrance 5300C GPS Receiver
On / off switch on Dell D-505
Take off the plastic strip with the power button on it. It will pull up on the right side and snap up and off. Then try starting it by pushing the power button on the board. If you have to press this button hard then it's worn out and will have to be replaced. If you don't have to press hard then the power button in the plastic strip is worn and misaligned and the plastic strip needs to be replaced.
Jun 26, 2008 | Dell Latitude D505 Notebook
Palm turns on but will not operate programs
You need to perform hard reset by pressing reset and power button same time.
Nov 20, 2006 | Palm m515 Handheld
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
