Question about Cameras
My kodak c813 wont turn on and neither will my boyfriends kodak
  • 2 more comments
  • bomays74 Jul 08, 2008
    Mine won't either!!! I put in the batteries (CORRECTLY!) and pushed the on/off button and the screen will flash once, and then NOTHING!!!
  • Anonymous Jul 28, 2008
    I have the same problem, my c813 wont turn on :C
  • amit79sri Nov 28, 2008
    I have the same problem .My cam is not turn on even i have tried with new batteries pls reply at amit4.srivastava@tcs.com
  • Anonymous Dec 28, 2008
    i just got mine for christmas on thursday and it worked all day thursday and most of the day friday and then it wouldnt turn on at all. i switched the batteries out for some brand new rayovac batteries and it still wont work..... anyone know anything?
I have the same camera (Dec 08) and also experiance the same problem. The cause is the poor position of the two small terminals for the batteries (under the battery cover). One of the terminals may not actually touch the negative (-ve) flat end of the battery. After some research, (??) I found that not all batteries are made the same and that duracel batteries have a larger metal area on the negative (-ve) terminal and therefore seem to work better. The problem is compounded by the fact that the batteries can also move around slightly, which means that sometimes it works and sometimes it doesn't I put some tissue paper just to hold the batteries in place... The real answer is to return the camera to Kodak, but until they redesign the batter cover you may end up with the same problem. This works for me, hope it works for you !
Posted on Jan 24, 2009
  • jme98 Oct 05, 2010
    Was about to throw the camera away until reading this... now after replacing with Duracell it works!! Thanks! :-)
  • aleclucas
    aleclucas May 06, 2012
    tried duracell and it worked first time!! thanks
Power on/off
Posted on Apr 09, 2011
3 Suggested Answers
leepania
  • 1099 Answers
SOURCE: wont turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Posted on Jan 06, 2010
BillB-SA
  • 2761 Answers
SOURCE: My kodak easyshare c813 camera but it wont turn on
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
My kodak easyshare C813 wont tern on i havent used it for a wile help
Are the batteries charged? If no replace. Were batteries left inside while the phone was left idle? Try and scrape the terminals. Try switching it on if it'll work.
Dec 06, 2010 | Kodak Easyshare C813 Digital Camera
Kodak easyshare c813 digital camera wont turn on ?
Having gone over a month with no response, I assume it was simply a battery problem.
Jul 16, 2010 | Kodak Easyshare C813 Digital Camera
Wont turn on
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
Kodak easyshare C813 screen
Hi, are you having issue on camera LCD screen that it will not show anything on the screen? Kodak Easyshare C813 has no feature to turn the LCD screen Off only Kodak Easyshare Z series and some M series that has a view finder that you can switch the LCD screen off and just use the view finder to save battery power.
You can refer to Kodak Easyshare Manual check this site http://www.kodak.com/global/en/service/publications/index.jhtml?pq-path=1398#otherDigitalCameras
For troubleshooting http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Nov 19, 2009 | Kodak Easyshare C813 Digital Camera
How do I set up my webcam on MSN for a C813 digitial zoom camera made by Kodak?
Kodak Easyshare C813 can only take picture, transferred pictures and video to your computer and record video. C813 cannot be use as a webcam if you'll like a kodak webcam you can check this products like Kodak S100 webcam, Kodak W100 webcam and T130 webcam. Check the website www.kodak.com/go/shop and for information about your camera you can visit www.kodak.com/go/C813.
Nov 15, 2009 | Kodak Easyshare C813 Digital Camera
Sep 26, 2009 | Kodak EasyShare P850 Digital Camera
It won't turn on and i have not dropped it
If your Kodak is less than one year old, then it will be repaired for free, under Kodak warranty, see Kodak Professional: SUPPORT CENTER or contact the number listed on the owner manual.
May 03, 2009 | Kodak Easyshare C813 Digital Camera
My kodak easyshare C813 WONT TURN ON!!
After searching and getting the run around, the only solution I've found is to BUY a new camera that IS NOT Kodak!!! I had never had a problem with Kodak until now...I WILL NOT buy this brand ever again!
Apr 03, 2009 | Kodak Easyshare C813 Digital Camera
Camera wont turn on
pull out slightly with a pin the two gold contacts on the battery door
Jan 27, 2009 | Kodak Easyshare C813 Digital Camera
Turning the light on when taking a video
with kodak easyshare c813 light not available in mode taking video
Dec 27, 2008 | Kodak Easyshare C813 Digital Camera
Cameras Logo
1,150 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
