Question about Fuji FinePix S602 Zoom Digital Camera
Adjusting light?? My camera doesn't work outside where its light out. The pics inside turn out great but outside they just look like a bright light with the flash off?? What should all of the settings be set on for normal pics.
  • 22 Answers
Did you check your settings? You may be outside of the range (red figures for speed and or f stop) in your selected mode, for example if you selected 1600 ISO for indoor shots and forgot to set it back to a lower ISO value.
Alternatively you can use AUTO mode, it's the most foolproof.
If you selected 1600 ISO don't forget, when you change the ISO to a lowe value, also put the camera back in high resolution, it stays in 1MP mode by default.
HTH...
Posted on Sep 23, 2008
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Purchased my S5 IS second hand (buyer beware!) and everything seems to work perfectly except the viewfinder is blurry. I can just make out the wording of the info around the edges but end up reverting to...
Pls. turn the little knob near the finder untill you get clear picture inside finder, previous owmer might have turn the knob for his eye sight good luck.
Nov 07, 2010 | Canon PowerShot S5 IS Digital Camera
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
I have a Nikon N60. Can't take pictures outside
can you manually change your f-stop to faster shutting. When the shutter stays open longer, it will draw in to much light. If you have an option for only outside pics, then I would try that as well.
Feb 06, 2010 | Nikon N60 35mm SLR Camera
My Kodak Z650 is showing lines in bright photos????
Hi!
The shutter doesn't work - the leafs may be stuck or the shutter cable is broken. You should contact your local Kodak service center.
Tom
Jul 25, 2009 | Kodak EasyShare Z650 Digital Camera
Outside pictures come out white
if the settings are auto and pics were ok b4 now started this oversxposed white pics
see the link it starts with overexposed pics outside and normal inside but u will see a red or pink or green tinge in pics
http://www.imaging-resource.com/badccds.html
pls contact service centre for free replacement of CCD i am sure they will do it even if u are out of warranty dont worry all are doing it casio will also do it
see link for europe support
http://www.casio-europe.com/euro/support/repair/dc/
US
https://www.casio.com/support/contactus/contact
pls rate me FIXYA for helping u
Mar 21, 2009 | Casio Exilim EX-Z77 Digital Camera
Fuji FinePix E550 got wet
FujiPix e500 got wet and doe's not work anymore. Can it be fixed and is it worth fixing?
Jun 25, 2008 | Fuji FinePix E500 Digital Camera
Digital camera . Konica Dimage G530. Problem Outside in bright light the pictures are all white. Pictures ok inside in low light. Video mode works ok inside and outside.
you need to adjust the exposure for that camera. since having too much light makes the photo all white.
Exposure and Focus Just as with film, a digital camera has to control the amount of light that reaches the sensor. The two components it uses to do this, the aperture and shutter speed, are also present on conventional cameras.
  • Aperture: The size of the opening in the camera. The aperture is automatic in most digital cameras, but some allow manual adjustment to give professionals and hobbyists more control over the final image.
  • Shutter speed: The amount of time that light can pass through the aperture. Unlike film, the light sensor in a digital camera can be reset electronically, so digital cameras have a digital shutter rather than a mechanical shutter.
Mar 21, 2008 | Cameras
Fuji FinePix S602 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
