Question about Samsung Televison & Video
I have a samsung lnr1550px/xaa it's brand new and it no warranty the t.v. won't turn on at all I checked the boards also the back sides for any burns or over heating I don't have a voltage meter with me right know to test threw the system but will this week was wondering if this problem has happened to this type of model and what would the repair be?
  • 70 Answers
The problem is most likely the lamp. turn on and if the lamp dont illuminate replace it .
Posted on Jul 07, 2008
Hi - we've just got a brand new Samsung c450 42" plasma. Its been okay for about 5 days, but tonight approximately 7 or 8 white and coloured lines have appeared vertically on the right side of the screen....
If it's a new TV take it back! There is a problem with either the PDP or the Y Buffer board. If it's still under warranty, call Samsung and have them fix it.
If not, are the lines pink? If they are clustered in 1 or more strips (usually about 3 in apiece), the Y Buffers are starting to go bad. Do not watch the TV - it may cause more damage and blow the YSUS board if this is the case! Replace the affected Y Buffer, and the lines will go away. I had to replace the upper buffer in my Samsung HPR4272X/XAA (my [3] strips were horizontal, and on the upper half of the TV).
If its the Panel, there is not much you can do about it (at least in my experience) except replace the panel. At that point in time, it's more cost effective to get a new TV.
Sep 27, 2010 | Samsung Televison & Video
I HAVE A samsung hpt5054x xaa 50" PLASMA TV THAT LOST ITS PICTURE DURING AN ELECTRICAL BROWN OUT. I HAD A SPIKE PROTECTED OUTLET BOX BUT THAT DIDN'T HELP. THERE WAS AN ELECTRICAL SMELL COMING FROM THE...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 01, 2017 | Televison & Video
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
Samsung hln567wx/xaa does not turn on no power to light
did you check the power supply board this could be the main issue
Jan 07, 2010 | Samsung Televison & Video
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Black line
I just had this problem with my Samsung 50' DLP HLR5067WX/XAA. Fortunatly it was still under warranty with Best Buy, so they fixed it for me. They had to order a brand new light engine. (or where the mirrors are, if i'm not using the right terminalogy) He said the problem is with one of the mirrors that has slipped (or slipping because overtime the black line will get thicker and thicker). I hope i'm saying it right, but it was with a tiny mirror that was slipping. Hope it's under warranty. I've also had 1x component plug burn out on me, my HDMI port went to ****, and he's gotta come back out because when he made the repair, the picture was reflecting too high up and to the left. (MLB 2k7 for xbox 360 - scores on top of screen are about 1/4th cut off). He said is next trip back to my house would result in me getting a new TV, so can't wait for his arrival! good luck with your tv
Aug 10, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
