Question about Clarion XMD3
Connecting my ipod to xmd3
Is there any difference in hooking up my ipod to the RCA connectors in the back or with the clarion cca.ipod connector
I believe that if you use the RCA connectors, you can use your iPod. If you use the clarion cca connector, you get more functionality from the dash of the clarion.
Posted on Sep 06, 2008
How do i get my clarion vz401 too play dvd videos from my USB
The Clarion VZ401 can only play audio (MP3 or WMA) files from a USB device. This is listed in the manual on both page 33 (USB Operations) and page 46 (Specifications). This unit can't play audio file with DRM and some USB drives may not be compatible with the device. It can play some videos from some IPod/IPhone models with the Clarion CCA-750 adapter. This is a USB to RCA composite stereo audio/video jacks cable. This feature isn't compatible with the Lightning connector or some versions of the iOS operating system. To view any other videos, you need to play them back on a device that can directly connect to the composite RCA audio/video ports (AUX In or AV In).
I hope this helps. The list of compatible IPod and IPhone models is available from Crutchfield on the VZ401 Details tab: http://www.crutchfield.com/S-ix4f1cAUkb9/p_020VZ401/Clarion-VZ401.html . This tab also has a link to the manual; the direct link is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20150407084800/Manuals/020/020VZ401.PDF .
Nov 18, 2015 | Clarion Car Audio & Video
Can you hook up ipod touch to a HD TV or media player
Yes. What you need is an adapter from apple, depending on the type of input your HDTV has. If you need composite, generally denoted by a single yellow RCA video connector and two (Red and White) RCA audio connectors, you need this cable: http://goo.gl/OlSDa Please note that Composite is not an HD signal. Although iPods are not able to output a true HD signal, over component (see below), they will output a slightly higher signal. If you require a Composite connection, denoted by three RCA video connectors (Red, Green and Blue, labeled Pr, Y, and Pb, respectively) plus two (Red and White) RCA audio connectors, then you need this cable: http://goo.gl/yk8Zt Also note that video out on iPods is only supported for certain video formats/video playing apps. Before buying a cable, you should most certainly research whether the videos/apps you are playing/using support video out.
Dec 31, 2010 | Apple iPod touch
How do you connect an Ipod throught the aux input?
what type of input does your radio have? if its a head phone jack input just get a headphone to headphone jack wire from radioshack and plug one end into you ipod and the other into the radio, set your radio to aux and your ipods volume to 70-80%. if its an rca input, it exactly the same but you will need an rca to headphone jack wire. if its usb, just use the cable that came with you ipod.
May 01, 2010 | Clarion XMD3
I cannot get the rca speaker wires to produce sound. i can get sound out of the hard wire speaker wires
the rca speaker hook ups are there to carry a signal to an amp and the amp to put a signal out to your speakers so with that being said you will not get sound out of them due to the fact that it carries a real real low power signal
Jan 23, 2010 | Clarion XMD3
I cant find the Part Number for the connector harness that has th
You will have your best luck at a local car audio shop that sells clarion. If your not sure where to find one, you can do a dealer search at Clarion's web site. www clarion.com Hope this helps
Jul 08, 2009 | Clarion VRX775VD Recorder
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
Instaling a Clarion XMD3
clarion website download + print
Jan 08, 2009 | Clarion XMD3
Clarion xmd3
Yes, there are 2 Red RCA jacks on the back. A $10 cable from radion shack, 2 RCA on one end and a 3mm jack on the other.
Cheap way to do it, there is also a device you can buy from Clarion that will do it for about $90 that gives you more control from the radio.
Jun 23, 2008 | Clarion XMD3
Clarion XMD3 Logo
725 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
