Question about Maytag Neptune MDG5500AW Gas Dryer
Gas dryer my maytag neptune gas dryer heats up for a few minutes and then runs cold until manualy stopped. any suggestions?
  • 2 more comments
  • dr diesel Aug 19, 2008
    there are no dials on this machine, it is all button/digital. i have disconnected the vent to eliminate that problem but it continues to heat for a minute or so and then cool down. i figured it had to be a part or the control board is going bad. i would appreciate any suggestions cause I'm fairly handy and would like to fix it myself without spending a ton of money or changing out numerous parts. thanks
  • Anonymous Mar 17, 2014
    The dryer stop heating and I found the problem to be the ignitier which I replced. Now it starts heating but after a few minutes hot air stop coming out. I replaced the gas valve coils but still the problem reamians.
    What should I look into next and where can I find helping videos or instructions.
    Thanks in advance for your help
    Marcelo
    The dryer stop heating and I found the problem to be the ignitier which I replced. Now it starts heating but after a few minutes hot air stop coming out. I replaced the gas valve coils but still the prblem reamians.
    Marcelo
  • Anonymous Mar 18, 2014
    Dryer heats when first started and sops heating after a few minutes and just blows cold air
    Genius:
  • 1,224 Answers
Blower motor relay is bad or the dials are bad
heres a way to check the dials
turn off the gas and run the dials if at anytime the dials stick during its cycle then you know this is the fault this usually the commen issues of all dryers the dials just wear out and so parts just dont work
also check the door switch this could be an issue why it gets cold clean out all vents and filters after "every use"
Posted on Jul 07, 2008
Dryer not heating
sounds like a faulty pc board starts heating and then their is no power going from board have come across loads of times
Apr 09, 2014 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
My Maytag Neptune MDG5500AW Gas Dryer heats up for a few minutes then stops heating. any ideas? thanks!
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
You will also find videos of disassembling most style dryers at the same site.
Nov 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer MDG 5500Aww Dryer runs and heats when cold, then after about 5 minutes the flame cuts off, after a few minutews, the ingiter glows red, but the flame does not come on again unless...
Hi!!
I seems like you have a plugged up filter and/or an obstruccion in the exhaust hose/pipe.
Remove and clean lint filter, also remove exhaust hose/pipe from back of dryer and remove any lint accumulated. Check also the exhaust hole in the dryer.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MayTag Neptune MDG9700AW Gas Dryer
Check the lint tubing and also for lint underneath the dryer. There is a blockage somewhere for this to happen. This is a built in safety feature for gas dryers that others don't have.
Jun 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
Mar 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
186 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
