Question about Whirlpool GEW9250P Electric Dryer
WP duet sport el dryer no power
No power to power button. Power source is good. Power cord is good.
  • 1 more comment
  • Anonymous Jul 14, 2008
    Will push the power button and does not start. Checked the fuse box and it is OK. It was working fine today.
  • nivy Jul 14, 2008
    The dryer-front loader Model # LER4634E20 will not start when I push the power button. I checked the fuse box and it is OK. What can we do. HELP!!
  • Anonymous Mar 15, 2014
    Trying to fit new power cord to wirlpool duet, which terminals do I use?
  • 1,224 Answers
Circuit breaker is bad
Posted on Jul 07, 2008
Whirlpool duet dryer
-Check your power source. make sure is not over load.
-Or disconnect main power and open back panel to visual check
all wire and connector. Possibly shock some where.
Good luck
Dec 20, 2013 | Dryers
He3thermo fuse location
That's always next to the thermal control on older dryers called a themo stat or thermo disc, newer dryers it is called a thermistor. The round fuse is located next to it. The idea is the control judges the air temp and shuts down the heating source. If for some reason the control malfunctions or lint blocks air flow the fuse melts and kills the power to the motor. DUET SPORT SERVICE MANUAL
Dec 05, 2012 | Dryers
Switch the 3 prong cord to a 4 prong on my whirlpool duet sport, 9 cycle
Hi mybabycamero
Go to the following webpage and you can see how to convert your 3 wire to a 4 wire dryer.
Please take time to rate me
Oct 17, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet sport dryer will not power on no lights nothing
check inside, white fuse should be near air flow . also near themo couplers, take volt meter ,place on continutee, first unplug unit. remove one ,of the two wire's. check to make sure circutt is closed ... if not rplace fuse.
Sep 15, 2012 | Whirlpool 279818 4Way Vent Kit for Duet...
Nothing works on control panel except control locked sensor light. The buttons were working fine then I went to add more drying time and the buttons do not light up or work.
From the details of your symptom you're indicating a possible intermittent loose connection between the user interface (touch panel) and the machine control board or the voltage supply to machine control board at P1 connector.
Disconnect the power cord from the power source.
  • Disconnect P3 and P4 connectors from the machine control board and then reconnect them.
  • Disconnect P1 connector and then reinstall the P1 connector and then recheck operation.
If the wires are good then you will need to replace the control board on your unit.
Here is a link to the part.
Jan 09, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
When the machine on it showing f-01
Tilt the washer back and support it with wood blocks so you can remove the kick panel screws and get the tech sheet from inside.
F/01 is an EEPROM error on the CCU. A power glitch may cause this error; unplug washer or disconnect power for two minutes. If broken, then you'll need a new CCU-- not a rare event on this washer.
s there a link to the diagnostic test for the washer? I found the one for the dryer here:
Jun 06, 2010 | Ariston Technologies AWD121WH
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Duet sport dryer control lock out on
stop coumting and just hole till light goes out if still no response try cutting power then hold power button down 10-15 seconds this may drain and remaining power to control and allow it to reset ..still problem probably control issuefront interface where buttons are most likelt
Jul 16, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250P Electric Dryer Logo
134 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
