Trying to install a brother printer (model 2170w), using wireless, have followed the steps using a network cable, however nothing appears to be taling to each other, not sure what to do next!
What o/s are you using?
Posted on Jul 07, 2008
Hi! I have a brother HL-2170W printer. It is connected via ethernet cable to a Dynalink RTA1046VW router (which is sitting on top of the printer) and I have a HP pavillion entertainment PC that is...
Hi!
Your Printer is connected to the (network) router via ethernet cable. Hence, it is a NETWORK PRINTER NOT A WIRELESS DEVICE, no matter your PC is connected to the network wirelessly. So, search for and install the printer as a NETWORK PRINTER. From the printer installation, it should searh and find the printer and susequently install the required drivers.
Moreover, you may checkout the followings link for instructions on how to install/ add a network printer.
LINK-1, LINK-2
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | Brother HL-2170W Mono Laser Printer
Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Jun 23, 2010 | Brother HL-2170W Laser Printer
We just got two brother hl 2170w printers from a lab across campus, they were configured for a wireless connection and now we are trying to connect them to the network via a wired connection. the test page...
hi there, this should work for you:
When you disconnect an Ethernet cable from the printer, wireless network will be enabled.
On the other hand, when the Ethernet cable is connected to the printer, wired network is enabled.
If you press the Go button for approx. 13 seconds, the network setting page will be printed out. Then release the Go button, wired network will be switched to wireless network even if the Ethernet cable is still connected.
You can then verify your network settings and change between wired and wireless setups.
Apr 16, 2010 | Brother HL-2170W Laser Printer
Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Jan 26, 2010 | Brother HL-2170W Mono Laser Printer
I am unable to setup the wireless feature for my Brother 2170W laser printer. Any thoughts?
http://download.brother.com/welcome/doc002311/cv_hl2170w_eng_nug_A.pdf ,<- is the link to the manual which explains in details how to configure the printer to connect to the wireless and how to install the printer on the computer.
Jan 23, 2010 | Brother HL-2170W Laser Printer
Hl-2170w offline problem on windows vista
I finally figured this out. Do the "cable" install. After it discovers the printer etc you will get to a screen during the driver part of the install that will ask you how to find the printer. The "recommended" list method is a deadend!  Instead, check the IP address option and input that.. You can get the IP address of the printer from the test page which should have already printed.(Its probably 192.168.2.3).  I run   XP and it solved the problem. I suspect its also the answer for Macs and Vista as well.
I have also had success by doing the "cable" install, then when its done, deleting the printer in Printers and Faxes, then doing a manual install (you still need the IP address).  I am using two computers to go to this printer and it flies. Great speed.
Jan 21, 2009 | Brother HL-2170W Laser Printer
Hl-2170w brother is offline
I just realized what my problem was with this same situation..."Off line". Do the following:
1. Reset the printer to factory default settings: turn off, turn on holding down blue button; after all LEDs light-up release button; All LEDs with go out then flash once.
2. Hook up the printer to an open port on your wireless HUB.
3. Install Brother software (note: go to programs/brother HL-2170 and select remove software prior to reinstalling)
4. Here is the catch: MAKE sure to select the correct encryption code. I was selecting TKIP instead of AES and two things happened...1) the computer did not pick up the printer on the network scan, and 2) the printer will remain off-line.
Once i selected AES, the computer found the printer on the network and viola' no more problems.
I then added my wireless laptop: installed drivers only, the programs scanned and found the printer on the wireless network and that was it. Now both computers are wireless!
HOPE THIS HELPS!!!
I do not know what I should type in beside the Network Key when I am installing my wireless setup for my brothers printer HL-2170W?
The network key mentioned is the security key that you use to connect to your wireless router. It is the key code you use when you connect a computer wirelessly to your router.
If you need assistance getting the network key please message me with the brand and model of your wireless router
I hope this has answered your question. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 13, 2008 | Brother Office Equipment & Supplies
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
