Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 won't spin, does everything else
My 70 agitates and drains just fine, but will not spin. After some inspection, the metal donut just under the drum rotates during spin cycle. But there is no linkage to drum above. Any ideas?
  • mercfoto Jul 07, 2008
    Dude, after looking at that awesome graphic, this was the part I identified as the culprit. Will order this right away!!! :) So how hard is it to replace? I'm fairly handy with cars, haven't dealt with washers yet.
    Ryan
  • mercfoto Jul 09, 2008
    Ok, got through it easy, but here's the thing....the plastic part isn't broken :( But the bolts were not real tight on the transmission. Would that cause the problem? After inspection, coupling looks good too and transmision seems to be turning properly, drive shaft too.
  • 481 Answers
  • there is a plastic part that releases the break when spinning. this part has broken.
  •  this whole kit in the picture sells for $35.00 and includes this piece.
  • the clutch needs to be replaced too so this kit is all you need.
  • item # 2670  repairclinic.com
  • it is a 20 minute job for an experienced person.
Posted on Jul 07, 2008
  • Mike Durland
    Mike Durland Jul 07, 2008
    it is easy,
    • take the case off (2 clips under control panel)
    • take out the agitator (one bolt in the middle 7/16")
    • lay the machine on its back (use one hand to support the back panel so it doesnt fip back and disconnect stuff)
    • take off the water pump (2 metal clips, leave water hoses connected, just use something to hold it out of your way)
    • take the motor off (2 bigger metal clips with 1/4" support screws, throw these away)
    • take off transmission (three 1/2" bolts underneath, when you pull the trans out make sure the washer stays on the shaft)
    • now you will see the broken plastic part and the clutch
    none of this will make sense until you start doing it.
    i left out small details since they will be obvious when you see it.
    i would change the coupling while your in there
    let me know if you get stuck
  • Mike Durland
    Mike Durland Jul 09, 2008
    • if the bolts in the transmission are too loose, then the plastic piece may not disengage the break (rare).
    •  can you turn the plastic piece  and spin the tub? you should be able to do it with your hand, turn it (i think counter clock wise) and you will feel the break disengage and the tub should spin freely.
    • check that plastic piece good because its just a small tabs that breaks off usually.
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore Series 70 won't spin
Sounds more like a transmission or a spin tube problem
Jul 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Wont agitate, drains and spins though.
Try these out:
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
please rate my suggestion...
May 21, 2009 | Kenmore Washing Machines
Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Apr 06, 2009 | Kenmore 24932 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
59 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
