Question about Microsoft Xbox 360 Elite Console
Xbox 360 Error
3 red flashing lights
My friend has that same problem but if u put a towel over the xbox and let it run for a while u can play it for a while it worked for him
Posted on Jul 20, 2008
How to fix the red rings on your xbox 360
1 Red Light Error -
Your system indicates this error when only the bottom right part of the ring is flashing. When you have 1 red light on the Xbox 360, it is usually associated with an error code you see on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft support site will give you the description and solution. Usually the problem lies on the DVD drive whether it is the wrong firmware or lacks a chip.
It may also be a hard drive error which can be resolved by taking it out and putting it back in or it can be a voltage error which usually occurs if you have added accessories to it. It is best to research the error code so you know exactly what to do.
2 Red Lights Error - One of the most common is when two red lights are flashing. No need to panic if you see only see the Xbox 360 2 red lights. Its sole meaning is that the console is too hot and needs to cool down. Power down the system and try again in a few minutes or if possible after an hour or two.
After giving the system some rest and playing in a much cooler environment, you should be back to your gaming in better performance. If the problem persists however, you may need to have it serviced to have the cooling issue fixed.
3 Red Lights Error - f you see three flashing lights, you are experiencing the infamous three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
At one point 1 out of every 3 Xbox 360 owners experienced this problem. This is the one error that you do not want to get. This highlights that there is a serious Xbox 360 hardware problem.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the warranty
4 Red Lights
If you have to get any flashing lights on your Xbox 360, pray that this is the one. If the entire ring flashes, it is a minor problem that indicates that the AV cable isn't connected properly or in rare instances, the cable is damaged. Make sure everything is properly connected and replace it if It still doesn't work.
Jul 21, 2011 | Microsoft Video Game Consoles & Games
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
3 red flashing lights on xbox360
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Feb 07, 2010 | Microsoft Premium System for Xbox 360
We have three red flashing lights on the on/off button when we turn the xbox on. The Xbox will not load.
3 red lights is the most common error it is caused by the GPU and the CPU overheating and to fix it you need to either get a good xbox 360 Repair guide or send it in.
Dec 11, 2009 | Microsoft Xbox 360 Console
Red flashing lights ,3 flashing red lights ,when we turn it on.
this looks like a useful page to diagnose your problem:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Oct 29, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
