Question about RCA 25404RE3 Corded Phone
Visys time/date display settings will not stay correct - help please!
This is my second RCA Visys 25204RE1-A replaced from Thompson Electronics.
The display settings for the time and date stamp will not remain at the current time and date. The date keeps resetting it self to 9/11 either by itself randomly or when a call comes in. Then all the cid's also revert to 9/11 at that same incorrect time making it impossible to know when I got a call.
I tried to set the date and time manually and by making a call. The time/date revert back to another time and the date of 9/11 again and again.
I was told to do a cold reset for 15 minutes and have done that several times. I was also told to use a 2 wire v. 4 wire phone connector cord. This things did not help.
If anyone knows of a solution to this please let me know.
Thanks in advance.
Tessa
  • tessa555 Jul 29, 2008
    Hi James9999,
    Wow, I thought it was only me who was having this nightmare. I Googled every where for a solution w/no luck. I cannot believe I wasted $70 bones on this phone either.
    Anyway, here is what I did over and over besides contact Thompson several times w/out any resolve. I think it has something to do with the voip modem in my case.
    The time date stamp still fails w/batteries when the power goes down or there is a surge. Then I get to do the following all over again.
    To reprogram the phone: (in this order)
    1- d/c power
    2- d/c jack
    3- remove batteries
    4- up-plug the voip modem
    5- wait 15 whole minutes
    6- reconnect the batteries
    7- reconnect the line cord
    8- reconnect the voip modem
    7- reconnect the power cord
    8- reset the time date stamp manually
    Since I do not have a data line I also used a 2 wire phone cord not a 4 wire cord.
    Seems in my case, the changing time date stamp has something to do with the voip modem reset #4 above. I also called my voip carrier to check my time zone was set properly, which is was.
    When the phone is reset to keep the time/date stamp the voip modem needed to be reset as well. I have not been able to duplicate the issue or find the exact cause why yet.
    Number to Thompson's Customer Service (if you don't already have it) is 1.800.511.3180
    They were not able to help much other than send another phone which did the same thing but not as much.
    Hope this helps and good luck! I know this is a royal pain to deal with! I will not buy another RCA phone again either.
    -=Tessa
Terrible phone. Not only resets time and date - it drops calls and the menu displays 'set time and date'. The customer service is equally bad. All round, a wretched product with miserable service
- Mark
Posted on Aug 07, 2008
I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
Posted on Jul 29, 2008
Speakerphone doesn't work
Possible. Check out your manual regarding speaker phone settings, etc.
Aug 29, 2017 | RCA ViSYS 2-Line Speakerphone
How to set time on the TIMEX t309t
Please follow these instructions:
Setting the Clock
1. Press and hold the 5 Time Set Button until the display begins flashing.
2. Press the 10 Reverse or 14 Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display.
3. After setting the time, press the 15 Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode.
Setting the Calendar
1. It is important to set the correct date in order to use the 7-5-2 Alarm settings. Press and hold the 6 Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display.
2. Press the 10 Reverse or 14 Forward Button to set the correct year, and then press the 15 Enter Button. The unit will beep and the display will show the month and day. Again, press the 10 Reverse or 14 Forward Button to set the current date.
3. After setting the date, press the 15 Enter Button or wait ten seconds to return to the normal display mode.
I hope I could help.
Thanks
Nov 26, 2011 | Timex T309TT Clock Radio
I just go the cannon mp27D and I am trying to set the time and date. I have followed the instructions very carefully but it still will not allow me to set either HELP Please
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
May 05, 2011 | Office Equipment & Supplies
How can I set the date on my watch? I could set time and alarm but I couldn't set the date .
Hi ajcruz_h,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Mar 04, 2011 | Timex 1440 Nylon watch
How do you change the date and time?
Hi amynoj1989,
Hope it helps.
Nov 07, 2010 | Timex 1440 Nylon watch
Need to set time & date on the cordless. RCA Model No. H5401RE1-A
From page 14 of the manual: "The time cannot be set manually in the handset, only at the base. Any update to the base time will be automatically sent to the handset."
Apr 08, 2010 | RCA ViSYS 2-Line Speakerphone
RCA ViSYS phone says "replace battery" but it doesn't have one
There is a battery box that holds 4 AAA batteries. It's down under. Not easy tospot but it's there. However, I added fresh batteries and it stil says replace battery. I'd like ot know how to turn off the message.
Feb 03, 2010 | RCA ViSYS 2-Line Speakerphone
RCA Visys 25204RE1 Message indicator light not working
If it works sometimes, then it might be a problem with the phone or the phone line itself.
If it never works at all, then it's a problem with the services that the phone company has enabled/disabled on the line.
If that's the case, call your phone company's repair line and explain the situation. They can check to confirm that the message waiting indicator service is provisioned on the line, or add it if it's not.
Dec 01, 2008 | RCA 25414RE3 Corded Phone
RCA RP5420B 2Band AM/FM Clock Radio
At the top of the clock, there is four positions for the slider. The first is shown as a key, which I assume is the automatic time setting mode. The second is Wake 1, the third is Wake 2 and all the way to the right is a manual time setting mode. If you slide it all the way to the right, you can set the time, then either keep it in that mode or return it back to automatic mode. Either way, you now have the correct time displayed.
Jul 04, 2008 | RCA RP5420 Clock Radio
RCA 25404RE3 Corded Phone Logo
1,239 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
