Question about Philips Magnavox MWR10D6 DVD Recorder
Recording error I put about three or four different blank dvds in but when i hit record,it says"recording error-can not record on this disc",but if i put a dvd in that i've already started recording on it does fine.When i have a blank dvd in onsetup it won't go to disc edit like it's already been finalized or even if no disc is in the disc edit is darkened and it won't go to it
    Problem Solver:
  • 5 Answers
My HDD recorder won't record to disc any longer. Have 2 different HDD systems and eventually it happens to all. Anyone know the problem? Is it the light inside?
Posted on Feb 19, 2013
Mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Posted on Jul 17, 2008
My DMR-E80H will no longer record onto blank DVDs
One solution is to clean the laser lens. Try using one of those lens cleaning CDs.
Also, sometimes the DVD may slip on the spindle, which may cause reading errors. Spindle cleaning usually involves taking the machine apart.
Oct 04, 2009 | Panasonic DMR-E80H DVD Recorder
Unknown disk, please check disk again.
did you finalize your dvd? also, the following describes the answer to alot of dvd error problems.
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Jun 19, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
DVDs from DVR don't play on any other DVD player
yes when you have finished the recording and preferably when the disc is full the disc must be finalised to be compatible with other players but be aware if you finalise a disc you cannot record on it anymore
Mar 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Philips Magnavox MWR10D6 DVD Recorder Logo
269 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
