Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
AC Input Line Produces Smoke
Washer is ~1.5yr old. I was running a heavy wash cycle with the hi-temp sanitizer enabled. I smelled electrical smoke and shut off the dishwasher. I removed the dishwasher from under the counter and ran a rinse cycle w/o incident. Then I ran the heavy wash w/ hi-temp cycle again and saw a small tendril of smoke coming from a silver box in the bottom right corner of the front of the unit. I checked the intallation guide and found that this is the AC input box for the unit. I pulled off the box cover and found a melted wire connector nut on the white AC wire (pictures below). Is this just a bad installation of this wire (I can re-strip the wires and replace the conenctor nut) or is there some other more serious underlying problem? Thanks for your help!
  • 2 more comments
  • geraldkleyn Jul 07, 2008
    What's interesting is that out of the box the dishwasher doesn't come with an AC line. The installation instructions include directions on how to attach an AC plug to the washer in this area and during installation, the technician did install this AC cord. So, either the installation was bad (it had a 90day warranty) or the wire nut melted over time. Do you think the manufacturer would take responsibility for it or call it an installation issue? Do you think that the wire nut failed because something else is wrong with the dishwasher (i.e. the motor is going bad and taking much more current to operate, more current than the wire nut can handle)?
    See additional comments added. Thanks!
    Yes, it was unplugged from the source before i took the metal cover off that protects the wire nut connection. No, it did not trip the ckt breaker. Thanks for the comments. I'll go ahead and replace the wire nut and check it for a couple cycles for leaks/smoke.
    Also, I should mention that a couple days before this started happening, my son fell onto the dishwasher door. The door still works fine, as did the washer (we ran it after he fell on the door without incident), but could this have caused a shock somewhere inside the unit that would cause this to occur?
  • geraldkleyn Jul 08, 2008
    Thanks. As I was pulling apart the defective line I found that the nut for the AC line clamp was not installed so there was constant tension on the wire nut. The common wire from the wire nut looked like it only had 5 strands going into it, this thin conductor line is likely what was causing the heat. I stripped the wires back and installed new nuts, reasembled and it is working fine. Thanks for the sounding board!!!
    Master:
  • 788 Answers
When your son fell on the door it cause have momentarily done something to the door switches or shorted something to cause your problem. I would replace that wire nut and make sure they are in the junction box and retest. Otherwise you may have a problem with one of the door switches, the heater or the thermostate.
Posted on Jul 07, 2008
    Scholar:
  • 135 Answers
Did u check for any water leaks?
    Novelist:
  • 121 Answers
It looks like one of the wires touched and shorted to cause that wiring nut to melt like that. What guage wire are they using? I would pick up a new pigtail. Is this 220 or 110? Usually 220 is used for washing machines. One other issue could be the technician used the old pigtail and the guage of the wiring is too thin causing it to heat up due to too much amp draw on the wiring. With the power turned off to this area try and trace the wiring back and make sure there are no cuts in the insulation. Keep me posted.
  • Justin Jul 07, 2008
    I also forgot to mention it might be best to contact the manufacturer if it is under warranty. Everything should be covered since an installer set everything up. That way you are responsible for nothing and they cant blame the installation on you.
    Sergeant:
    Champion:
  • 230 Answers
The problem is because of the melted wire only,but dont repair by own ,because yours is only one and half year old so go for warranty.repairing by own will void warranty,so give to service center with warranty
  • Maytag Master
  • 19,396 Answers
Motor power absorption does not cause this kind of effect, it looks more like an ordinary short, a defective cable, or water leaking a not well insulated cable.
Probably some water on the cable caused the short. Replacing the cable in the proper way, and ensuring insulation can sort it out.
    Scholar:
  • 77 Answers
Ensure the unit is unplugged! It looks as though this connections is directly attached to the cord that supplies the unit with electricity. With that being the case, from your little caption, one of your questions is "did the connector fail" and also "is this common". One, wire nuts do not typically fail. When you have a loose connection, this causes heat, this connection looks as though it is connecting the neutral for this unit to the neutral from the source. Neutrals are a return path to it's source. With a connection that is loose it will eventually heat up to the point of melting the insulation and eventually breakdown the connection to the point to where it fails. You could possibly peel back the insulation on both wires until you find good copper wire and re-connect tightly with a new wire nut. Run a new load and examine carefully. It should work without incident. You may also check for any possible leaks as water could have caused a similar issue. Did this happen to short out the circuit breaker or the ground fault located under the sink where it is plugged in?
Good Luck
  • Thomas Van Tress
    Thomas Van Tress Jul 07, 2008
    Just a clarification to add to my original solution. The "HOT" is the black wire from the cord. I will tell you that the wire that got hot is the nuetral as this unit looks to be being fed by 120v. I will also say that the neutral does carry current and has the potential to have the same current (amps) as the unit is capable of using, but if the neutral stays closed or connected with your system neutral it will always be considerably less than the black wire as this is the hot wire that supplies the unit with voltage and has the most current flowing through it. If you were to follow all the neutrals back to your service panel you will see that they are connected directly to the case of your service panel as is all of your grounds. If you had a 3 prong plug feeding this unit, it would ensure polarity when plugging it in i.e. neutral prong would have to go in on the left when you plugged it in with the ground being on the bottom. You can still get electrocuted with an "open" neutral because the unit requires the return path to the source, in this case it would the service panel. Electricity must flow to the appliance and have a return. If either is opened the appliance will not run. Likewise any loose connection with either of these will create heat. Since a technician installed the connector, they would be my first call to see if they will stand up to their work that they did as this could have caused a fire!!
    I hope this helps.
  • 2,326 Answers
I would suggest to contact the manufacturers first, since this seems to be a manufacturers defect because under any circumstance the wire should melt that way even if they were loose from day one still manufacturers responsibility.
I would suggest to click here to find out if your model number has been recalled.
If you decide on fixing it yourself, you can just strip the wire and re-attach it making sure you isolate the exposed areas with a heat resistance insulator tape.
  • Jaime Hernandez Jul 07, 2008
    Check the installation guide for proper wiring diameter(AWG). Normally if these appliances operate at their maximum, they will draw higher currents but it does not mean the motor is bad or going bad.
    Your son incident wouldn't have nothing to do with this failure.
    It appears that it happened overtime.
    Genius:
  • 1,847 Answers
Yes you can re-strip the wires and replace the conenctor nut. the melted wire were the reason of loosely connected wires that increases the temp od the wires and melt it.
  • Legin Varghese
    Legin Varghese Jul 07, 2008
    make sure the wire are tight (connection) properly else it will do he same thing again in a weeks time.
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Lg tromm front load washer smells like burning and going to catch fire?
Unplug the washing machine from your electrical plug immediately, and do not run the washer at all. The longer you run the machine with smoke coming out of it, the more expensive will be the repairs. Not only that, but, you could have smoke damage, and cause yourself health problems by breathing in the toxic smoke. Your question can only be answered by physically inspecting the machine. Please have it serviced by a qualified service technician.
Nov 25, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Weird smell
Probably mildew. They often suggest running a bleach only (no clothes) cycle every month or so with front-loading washers.
Oct 09, 2006 | Kenmore 44102 Front Load Washer
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
141 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
