Question about GPS
I have an apelco 182xt receiver and it does not send any info other than its last position fix, which was in australia. the unit is now in new zealand.
pctech1
  • 1940 Answers
SOURCE: I have lost all UK & Europe mapping - except
The maps are stored in specific mapset files with *.img extension in the flash memory of the GPS unit. Each mapset file contains one or many maps in it. Beside that, the Garmin GPS navigator can also recognise and load up one additional mapset file from SD card residing in the "Garmin" folder and named as "gmapsupp.img".
Here are the mapset files supported by Garmin Nuvi 255w GPS navigator:
  • gmapbmap.img - the default base map
  • gmapprom.img - the primary mapset
  • gmapprom1.img - the secondary mapset
  • gmapoem.img - the OEM mapset that cannot be unselect by user (if it exist)
  • gmapsupp.img - the supplemental mapset which you can have one in the GPS flash memory and another one in the attached SD card.
Therefore, the Garmin Nuvi 255w GPS supports up to 6 mapset files, including 1 in SD card. Normally new maps installed by the user will be stored in gmapsupp.img.
You will lost all the maps in the previous mapset file if it is overwritten by a new file with same filename. If you want to keep the existing maps, ensure that you store the mapset file with an unused filename (from the 5 filenames above). Alternatively, you can make use of special tools to merge new maps into existing mapset file.
You can view the name of your base map in Tools > Settings > System > About > Basemap.
You can view the name of maps in the other mapset files in Tools > Settings > Map > Map Info. There, you can tell the GPS to load the map by checking on its name, or not to use the map by unchecking it.
In case there are 2 or more non-overlaping maps available for the same location, the map with the highest priority number (defined in the map itself) will be used by the GPS.
Note that certain map which are locked by vendor need a 25 bytes unlock key stored in a *.unl file in the same folder and with the same name as the mapset file where the locked map is stored in.
You might probably also interested to read:
Posted on Mar 13, 2011
How do I get the devise to work here in Australia
probably does not have maps installed for australia.
Mar 26, 2015 | Garmin nuvi 1350 Car GPS Receiver
I bought this devise in USA last year where it worked very well.I fished it out the other day but it doesn't work here why?
When you mean does not work, does the unit power up or is it plain dead? If it does not turn on, then you will need to troubleshoot or send out for repair.
If it turns on, but does not provide you with maps, you need to load maps for Australia as you currently have US maps loaded on the device.
Google search for Australia maps for your unit, or contact Garmin customer service.
200 pin unlock
Only way to have the unit unlocked is to enter the correct PIN # or take the unit to the area where the PIN was set and it will auto-unlock. Last option is to send the unit to Garmin. More info can be found here:
http://www.sharc.net/gps_lost_pin.htm
Sep 27, 2013 | Garmin Nuvi 265W GPS Receiver
I forget unlock pin for garmin 265w serial number 1r2158775
Sep 27, 2013 | Garmin Quest GPS Receiver
Unlock receiver code
I am trying to change my country from 'North America' to 'Australia' Please help. I deselected 'North America' in Tools, Settings, Map Info. Now not sure ?
First do you have a map of Australia on your satnav. If you have it should appear in Tools, Settings, Map, Map Info. Also it should be ticked or selected. If it's there all you have to do is:
  • Press WHERE TO
  • Press ADDRESS
  • At the top of the screen you'll see the last country selected i.e. North America and at the bottom you'll see CHANGE COUNTRY
  • Press CHANGE COUNTRY and select AUSTRALIA
If you don't have a map of Australia installed this won't work of course so you'll need to buy one from www.garmin.com
Mar 29, 2011 | Garmin nuvi 255W GPS Receiver
Broken screen, cracked. bottom touch controls don't work?Where can I get that fixed ? Thanks Bill Grand Rapids Michigan
Sounds like a new one is required Bill. As far as I know they don't fix stuff but at least for Australia and New Zealand they offer a heavily subsidised price for a new unit. Also try on the zumo forum www.zumoforums.com/
Nov 03, 2009 | Garmin zumo 550 GPS Receiver
Tom Tom One XL Repair Center???
The cost of having a new motherboard fitted exceeds the cost of a new GPS. Try one of the new Altinas 8010a . Marbella Australia have them on their site and will send to USA quite cheaply they are excellent and quite robust.and the exchange $ has never been better
Jul 25, 2009 | Tomtom GO GPS Receiver
Unit indicates mapcard not inserted properly but it is
card is possibly blank send it back. buy a marbella altina Nextar are unreliable GPS If in Australia see www,nettiser.com.au/marbella/
e3ven outside australia the maps are available for all countries and the unit is reliable and easy to service, also has a mkap backup service if registered.
Jun 20, 2009 | Nextar X3-03 Car GPS Receiver
Is it possible to track a stolen GPS with the serial number?
Garmin has a large hard drive with all the points of interest inside the device.
All the device does is read the GPS coordinates that are broadcasted by the GPS satellites and processes data based on what it receives. It doesn't need to send any information to a central server.
If GPS was able to communicate two ways, there wouldn't be a need to purchase map upgrades for new roads, points of interest, etc...
I just got my Garmin stolen within the past 23 hours, and as much as I wish there was a way, there isn't...
Nov 26, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
62 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
