Question about Sony KP-57HW40 57" Rear Projection Television
KP-57HW40 Flyback Removal & Replacement
Okay, so I have a rear projection tv and it's flyback transformer is going bad. I know these things are dangerous and can easily kill a person. So before I go trying to take it out I was hoping someone could share thier knowledge of safety when removing these. It's amazing how little info I could find on the net about safety. I'm also curious on how the red wires are removed from the flyback. I know they don't just pull out, at least not easily. The flyback is Sony part number 145328521. Any help or a complete walkthru on what to do and what not to do would be greatly appreciated. This is a great HiDef TV and there is no reason for it to go to the dump for a part that will cost me $70 just because the repair man wants $400 to do the repair.
Thanks in advance for your help.
  • myanez28 Sep 30, 2008
    I have the same tv and the same problem. Please notify me when you can offer a walk through tutorial in removing the fly back transformer.
    Regards,
    myanez28@yahoo.com
    Genius:
  • 1,199 Answers
USE A INSULATED SCREWDRIVER (RUBBER HANDLE) RUBBER GLOVES WILL HELP ELIMINATE SHOCK
Posted on Dec 07, 2008
    New Friend:
  • 50 Answers
Yes its dangerous because of its high voltage, but you can remove it yourself, just unplugged the power cord, then get a screw driver insert it to the high caps connected in the flyback its color red push the pin inside and pull it off be sure not to touch the metal part of your screw driver, then thats the time to unsolder it...
Posted on Aug 01, 2008
I have a Sony kp-51ws500 that shuts off and blinks 8 times, I'v read that some other people have had the same thing and it was the flyback transformer. Now my tv has just a green screen with no pi
No, the set is prone among other things to issues with the three picture tubes, go to unused video input----screen should be black with only the input label displayed-----in your case with Green screen and or slight diagonal trace lines (if there) the Green screen control itself needs to be adjusted slightly down.
I can tell you if you want how to do that---requires only a screwdriver and 10 minutes.
Dec 03, 2012 | Televison & Video
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Jun 26, 2011 | Sony KP-57HW40 57" Rear Projection...
KP-46WT510 is blinking 8 times repeatedly on standby what is the problem?
Replace the Flyback transformer your correct flyback which is used in the WS510 and WT510 models is available at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328551/cName/flybacks
Oct 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
KP-57HW40
IT MAY BE YOUR FLYBACK LOCATED ON THE D BOARD COST AROUND 70.00 FROM SONY PARTS #145328521
Nov 01, 2008 | Sony KP-57HW40 57" Rear Projection...
My KP57HW40
TRY REPLACING THE FLYBACK ON d BOARD (AROUND $70.00 FROM SONY) THIS WILL FIX THIS MOST COMMON PROBLEM ON THIS MODEL
Oct 25, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500
8 times flash shows error in Flay back Transformer on D Board.
Fly back Transformer part number is ... 1-453-285-41 FBT ASSY, NX-4006
It is available at Part Store on $112.00
All above info are based on your question and feedback.
Good luck.
Sep 29, 2008 | Sony KP-57WS500 57" Rear Projection...
My projection tv
Could possible have a bad Red CRT or
the red's main width is too wide and th eimage is wrapping around the tube. Could be a bad red drive.
Jun 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Big Screen Tv
Your flyback transformer is probably bad. It will need to be replaced. You could also try adjusting the voltages to the crts from the flyback. There is a set of 6 screw like pot knobs just behind the speaker grill. The bottom three knobs are the ones you want to adjust. Do it very very slowly as it shouldn't take much to correct the problem.
Jun 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Please Help
no its not the speakers, i think it is the flyback transformer that is arcing.
Jun 06, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
421 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
