Question about Dryers
The drier squeaks when turned on - Dryers
  • met251 Jul 07, 2008
    my dryer also started squeaking as it tumbles. Does dry the close but is noisy
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/0088_8_1.asp#Level1_7
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 07, 2008
Fex831fso squeeky drier
Good Morning Friend,
I understand that the dryer is squeaky on your Frigidaire laundry center, model# FEX831FS0. There could be numerous possibilities causing the squeaking sound in your appliance. I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine what is causing the squeaking sound. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer is squeaking, but I'm reading about several possible solutions. Could it be a belt, guides, or bearing, or all 3?
I previously worked on an electric version of this drier. You're right it could be any of the above. To diagnose you need to:
1. disconnect everything - at least switch off electricity and disconnect the duct so you can remove the back cover, and / or tip it on its side.
2. the electric motor is near the bottom with the drive belt looping up over the drum.
3. Is the drive belt loose? Pull on it (or the the drum) to test for slippage. If so that's your problem. Repair /recondition /replace as appropriate.
4. If the belt was tight, run the drier on cold with the cover off (taking appropriate safety precautions, and listen to hear where the squeaking is coming from.
5. If its the motor, you have a bearing problem, otherwise consider guides.
Sep 02, 2012 | GE Dryers
Amana LE7153WM drier will not start... makes a low humming sound when you push in the select dial to start the drier
Hi John, W/D here.
Most likely scenario: squealing was either a belt or a bearing. Failure to run is probably a broken belt. Gain access to the back of the drier, with the power disconnected. Open the back and check the belt. If broken, replace it, and then rotate the drier by hand, listening for additional squeals and squeaks. If no other issues are noted, replace the back cover, plug it back in and try it out.
Best regards, --W/D--
Nov 09, 2011 | Dryers
Gas drier still works but has developed exteme vibration
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
My frigidaire crown series frt load drier makes a loud squeaking noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 18, 2011 | Frigidaire Dryers
Making a squelling noise while turning the drum by hand,and while the drier is operating.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Whirlpool LER4634J Electric Dryer
My dryer squeaks horrible while running. It has broken 2 belts in 3 weeks. What is wrong?
Jockey pulleys are faulty you will find squeak alters as drier heats....
Sep 29, 2009 | Dryers
Gibson heavy duty dryer. how do I open it up to replace the belt?
My drier is squeaking when first turned on.After about 5-6 mins.go by it is fine.
Oct 09, 2008 | Dryers
Dryers Logo
344 people viewed this question
Top Dryers Experts
