Question about Toshiba Satellite A105 Notebook
Shutting down My computer seems to get to hot and shuts down..What's the problem?
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Nobody is going to answer your question since you give bad ratings for those that answer your questions entirely. Come back and rate the other post that I answered correctly.
Try blowing air into the cooling vents/fans; they might have dust in them
Posted on Jul 12, 2008
Computer shutting off
shutting off when? Shutting off immediately when you try to start it? Shutting off after it has run for a while?
If it is shutting off after it has run for a while, then it is probably running hot. If you try to restart it immediately it will not boot. If you let it cool off for a while then it will boot successfully (definitely a sign of running hot).
Things that make a computer run hot:
1) Dust in the vents, fans, cpu & heat sink and all inside the computer.
2) Fan not working
3) The Thermal Paste on the cpu and heat sink has either dried up or is too thin to keep it cool.
If it shuts down immediately after it has been sitting for a while then it's not running not and your system has some other problem.
Mar 31, 2012 | Computers & Internet
Inspiron 530 desktop--- computer boots up, runs just fine for a while, then monitor displays gabled multi-colored patterns, then evetually shuts down.
What is shutting down, the monitor or the computer. Check the power light on each for proper diagnosis. You either have a bad monitor, a bad video display card or a bad PC, specifically a power supply or motherboard. This is a classic symptom of something getting too hot and shutting down. One way to test the monitor is to plug it into something else for an a period of time and test. If you're PC is shutting off, try unplugging unnecessary peripherals, i.e. CD/DVD drives, floppy drives, external USB peripherals, etc. Start with just the video adapter, keyboard, mouse and monitor. Let us know what is shutting off, for further diagnosis.
Aug 13, 2011 | Dell Inspiron 530 Desktop Computer
Sir when i starting my computer after half an hour it was shutting down suddenly i can i do sir
Seems it could be virus issue, but still check do your computer shutting down when you click any application, to know is it hardware or software issue try to boot the pc in safemode and calculate the time do it shutting same like in normal mode this will help you to understand where could be the reason hardware, software or virus.
Jun 18, 2011 | Intel Computers & Internet
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
My HP DV1000 keeps shutting down whenever I watch videos or do anything on my computer which is more than the basics of surfing the net. When it shuts down, the computer is hot so I attempted to remedy the...
hi this all hp is getting same problem
i have solve many, but u need to open up ur notebook and have to do all cleaning ,u can open ur notebok,
or else do onething, uses vaccum cleaning ,see behind ur laptop a fan site **** all dust through vaccum cleaner, it will clean and problen shouild be solve or else u have to open whole notebook
thanks a lot
Aug 16, 2009 | HP Pavilion dv1000 Notebook
Computer shutting down
  1. Be sure your power supply is working and charging battery
  2. Allow battery to full charge
  3. Be sure PC is cold not hot or warm
  4. check if before shutting down PC fan is starting: if not starting PC thermal protection can be triggered and your fan out of service.
Jan 14, 2009 | Acer Aspire 3000 Notebook
My laptop is shutting down after less than 45 minutes usage. It seems it might be getting too hot
Try working on your laptop when you are in a much cooler environment than the usual. the possible reason for your laptop shutting down could be either the processor is getting to hot due to which the cooling unit of the system i not able to cool it down & keep the system temperature under control. I would also like to know the model of the system that you are using at the same time would also like to know the approximate age of the computer that you have been using. I possible which brand is your system & whats the Os its running on... thanks & regards
Jan 13, 2009 | Computers & Internet
Gateway M-1625 shutting down few times a day
I am havin the same problem at the company i work at. The problem with our machines has to do with the mother boards. But you might want ot check the power supply and make sure it is rated high enough to run your system. Next check/blow out your CPU cooler, and go into bios and see if it is set up to shut off at a certain temp.
Dec 21, 2008 | Computers & Internet
Laptop shutting off
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Jun 11, 2008 | Gateway 7320GZ Notebook
Toshiba Satellite A105 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
