Question about Rowenta DG-980 Iron
Rowenta dg980 I was excited to find your repair advice regarding the steam button.  I have ordered the replacement trigger assembly.  The only problem I have now is that I don't know what size security torx bit to order to remove the screws!  Any advice would be sincerely appreciated!
    Scholar:
  • 70 Answers
I found out that you do not need to remove the security torx screws (you can get a set from Kragen's Auto Supply or Harbor Freight Tools); don't mean to advertise, but they have decent prices for any "Do It Yourselfer' arsenal." Use a wooden popsicle stick and gently pry the soft rubber cover from the front (on either side) toward the cord end, just enough to access the trigger/control switch assy from the top. Good luck and keep in touch.
Posted on Jul 11, 2008
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Where can I order the steam trigger part that is broken. I need the part number. It is a Rowenta DG980. Thanks
Rowenta RS-DG0123 Knob Trigger, Blue
http://www.smallappliance.com/product.asp?pid=4477&cur=USD&cam=GA_B_rowenta_part
Carefully pry off blue handle cover on top with a popsicle stick.
A quick (maybe permanent) fix while waiting for your part: you can "weld" the plastic trigger back together. It doesn't have enough surface area for glue. Position the break back together. Secure parts so they don't move. Heat a medium-small flat blade screwdriver until it will just melt the plastic with a gentle touch. Touch the tip parallel to the break and melt a shallow groove about 1/4 of the way into the break. You should be centered on the break so you melt a bit of each piece. This will be the start of melting the two pieces together. Now, as you do each side of the break, use the flat of the blade to "trowel" the curled up plastic back into the groove you just made. Be careful not to distort the side that activates the switch. Ours is holding so well that I keep the new part in case this ever breaks again.
Less is more: use only enough heat to melt the plastic with a gentle touch. If it's red-hot you went WAY too far. You can always try more heat, but if you fry the part, you are done until your new part comes.
Sep 14, 2011 | Rowenta DG-980 Iron
My Rowenta Master Steam Generator - Steam button turns on but does not turn red or heat.
- First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock!
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in if the reservoir is dry and the red light comes on indicating it is out of water.
Generally, if you remove the blue water reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat converting the residual water in the system to steam, for at least one or 2 "bursts of steam".
If all this works, then likely the $75 electronic printed ckt board driver detector is okay. It enables the flutter pump, fills the boiler with a few tablespoons of water to be converted to steam and repressurizes the steam system. It is the sequence logic this board does that you can use to determine the bad part, find and replace it yourself. There are many thermostats and sensors and without a schematic it is tough to reverse engineer.
The most expensive parts are the tank heater and sole plate elements followed by the ckt board (make sure you label all the connections & draw a color coded diagram before replacing this part) especially likely if the flutter pump does not turn on and everything else gets hot & steams is okay if unit less than 5-10 yrs old. BTW a new unit is $350 so you have to weigh your options and talk estimate for repair with repair tech if you go that route. A lot can be said if your unit is not that old, have used clear water, allowed steam to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual. It is worth the price to repair OR replace. It is a great machine.
May 16, 2010 | Rowenta DG-980 Iron
Trigger button broke during ironing. What to do?????
The fix is easy, order the trigger that has an actuating tab that is probably broken off. Gently pry up the blue cushion from the front to the back near the cord and you will see the tab lying over the switch. I order my parts from the Rowenta Region Service Center below:
Keep us informed as you resolve and solve the problem. It is a fine machine and well worth the repair.
May 10, 2010 | Rowenta DG-980 Iron
I have a few Rowenta DG980's that won't stop steaming
I would be more inclined to believe the trigger steam switch is jammed or hung up in the housing. It is a small micro-switch inside the handle under the trigger actuator. You can pry up the blue cushion from the handle from the front towards the back cord using an orange stick or screwdriver but not damage stuff. The button nib may be jammed against the switch hole/housing. Look here for getting parts...
Apr 15, 2010 | Rowenta DG-980 Iron
Power switch blew
you can go to small appliance.com and buy a
new switch. i have do this and orther parts .
for the same model.
Aug 27, 2009 | Rowenta DG-980 Iron
No steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Dec 18, 2007 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
336 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
