Question about Nintendo DS Lite Console
Time Date When I turn my sons DS on it says."before you begin, you must adjust system settings. Please touch the Touch Screen or press any button"...so...I go through the steps...#1. Set Name...no prob..it saves..#2 Fav Color...great..saves again #3...set date...I set it...confirm...then when I go to step 4...the date resets to 01/01/2000...Step #4...set time..set...confirm..save...then it also goes back to 00:00...then step #5..set birthday...that sets and saves fine...then it says to turn on the ds for the changes to be saved...then voila..back to step on again...
  • weewinkle1 Jul 07, 2008
    srry,,,should say turn off the ds for the changes to be saved..
  • weewinkle1 Jul 16, 2008
    thanks xedcom...tried to clean it...nothing...just replaced the ds..they are cheap enough that it probably wasn't worth my while fixing
    Novelist:
  • Nintendo Expert
  • 127 Answers
Clean your battery contacts and DS pins with alcohol.
If not working then you have a deffective mainboard and need to take your DS to warranty or repair.
Posted on Jul 12, 2008
  • 61 Answers
When you fist turn it on you need a name just hit any letter, then hit the A conferm all the way across the board (A for everything) turn the system off wait 10 sec. turn back on you now should be able to change whatever you like without any trouble
Posted on Jul 18, 2008
How to reset time/date
25592762-obkoyhm2j4njygclebv1o4cu-2-0.pngTwist the wheel on the top of the camera to Settings icon 25592762-obkoyhm2j4njygclebv1o4cu-2-5.png Then follow these steps:
1. Touch [General]
2. Touch [Date/Time Set]
3. Touch the Up and Down on [Year] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Year].
4. Touch the Up and Down on [Month] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Month].
5. Touch the Up and Down on [Day] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Day].
6. Touch the Up and Down on [Hour] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Hour].
7. Touch the Up and Down on [Min] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Min].
8. Touch the Up and Down on [AM,PM] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [AM,PM].
9. Touch the Up and Down on [DST] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [DST].
For a simulator view and instructions, follow this link:
http://samsungsimulator.com/output/service/simulator/c5ed71e7-d3c7-47ce-9c7c-a9b632320ee9/#!topic/settings/date_time_set
The manual for the Samsung WB350Fcan be downloaded here:
Global Download Center
Mar 19, 2015 | Samsung WB350F Smart Digital Camera,...
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Just received a used ds lite from ebay. when I type on the screen it enters the letter next to the one I touched. Is this a serious problem? Never used a DS before; will this have an impact on game...
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
icon_settings.gif Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
    icon_calibrate.gif Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
Dec 02, 2010 | Nintendo DS Lite White Console
How do you change system date on ds
SOURCE: http://www.nintendo.com/consumer/systems/ds/time_date.jsp
Changing the date
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Apr 15, 2010 | Nintendo DS Lite
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not...
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Sep 04, 2009 | Konica Minolta Office Equipment & Supplies
Doesn't have the directions to touch to begin
It sounds like a system crash. If you take the battery out and reinstall it a few minutes later this will reset the system and should solve the problem.
Aug 29, 2009 | Nintendo DS Lite Console
The touch screen on my sons leapster doesnt work.
Buy another one from the same store and just swap them.
Feb 20, 2009 | LeapFrog LeapSter L-Max Console
System settings won't save... Nintendo DS
hi im 9 and i can help you save your settings by turning off the ds and then try to save everything you need and then dont shut close the screen there you go. and fold it back up and it saves
Feb 07, 2009 | Nintendo DS Console
Nintendo DS touch screen not working properly
Turn the ds on without a game in it and go to the settings icon (looks like a tiny ds) on the bottom middle of the screen then go to the far right yellow icon and it will re-calibrate the touch screen and let you know if calibration was a success.
Jan 11, 2009 | Nintendo DS Console
Nintendo ds
Setting the Time and Date
Changing the time
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
Changing the date
Dec 30, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
451 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
