Sennheiser MKE 300 mike cable broken. Can I repair myself? preferably with something less prone to breaking
    Genius:
  • 2,035 Answers
Please connect the same color wires once you strip the broken wire at the two ends , match the same and connect and check if it works....
Posted on Jul 18, 2008
  • 13,433 Answers
Yes I suppose you could fix it yourself, but I do recommend getting a original replacement for it.
The microphone is very simple device, there are 2 maybe 3 cables that you need to wire and connect to the connector in the right spots. You would need to test the old cable to see which wire connects to what.
  • 1 more comment
  • Ekse Jul 18, 2008
    I had a look at the microphone and it has 2 wires inside the cable,
    Ground and signal.
    This is a very easy fix really..
    Rewire the two wires inside the cable and connect the two cables to the plug, thats it.
  • Ekse Jul 18, 2008
    when I was 7 my father had me down in the garage with him fixing hes cars. I could probably have fixed your mic back when I was 7 so really this is very easy. the type of wire you use may effect the quality, maybe ask a local shop for a professional opinion on what wire to use on it.
  • Ekse Jul 18, 2008
    if this is your mic
    I can see the connector has 2 wires inside judging from the connector head. if the old connector is broken, get some good quality wire and a good plug for it from a local shop, you can fix it yourself.
    Genius:
  • 1,847 Answers
Yes you can replace the cable.
Posted on Jul 07, 2008
  • Legin Varghese
    Legin Varghese Jul 07, 2008
    but yes you have replace it with same cable not with somthing less prone to breaking. there is no other option.
My sennhauser 110 only work on left speaker ,nothing ,no sound on right?????headphones
The first thing to do is to disconnect the Sennheiser wireless unit and try another headphone, preferably a cable type and see if both channels work. If the sound is OK on both channels, the fault is within the headphones. If you are lucky it will be the wireless unit plug or the cable and can easily be tested and repaired by somebody familiar with electronics. Otherwise you will probably need to have it repaired by a service shop or a technician. I hope the guarantee is stilll valid.
Sep 16, 2015 | Sennheiser RS-110 Wireless Headphones
My porter cable Finish Nailer 250B has a broken part. It is 119 by the parts list and Part number 904695. It looks like it does not come with gaskets/o rings. Is this something I can replace myself or...
You can reuse the oring from the old cylinder. Easy to install. The cylinder will break when the driver bends or breaks. If the driver looks good, dont worry about anything. Remove nails. Slip the driver into the cylinder and push driver and cylinder into body of the gun. Replace head.
Apr 29, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
Can I get replacement parts for the mke2-4 such as the connector, the cable etc.? and if so where?
You need to contact Sennheiser direct to get replacement parts - http://www.sennheiser.com/sennheiser/home_en.nsf/root/professional_wireless-microphone-systems_lavalier-mics-mke-2-4-gold-c
Mar 17, 2011 | Sennheiser MKE 2 Gold Professional...
Sennheiser HD 205 Headphones. My cable has had its fair share of pulls and tugs over time and finally the left ear stop working. By fiddling with the cable i was able to get sound from the left ear, but...
Hi, Ian, If you have soldering experience, you might be able to replace it by yourself. If you remove the portion of the wire that is frayed and replace it with new wiring, it might work. If you feel comfortable doing this, I would say go ahead. However, it might be just as cost-effective to take it to a local audio-repair shop and have them do it. I have had multiple sets rewired myself, and it has cost less than $20 each time. Either way, it should be a relatively easy and cheap fix.
Feb 25, 2011 | Sennheiser HD 205 Professional Headphones
Cable broken - i need to put a new ending. How do I wire the ending?
You can find the answer by clicking my user name and looking at the tip for headphones.
Feb 16, 2011 | Sennheiser CX 300 Consumer Headphones
How do I take my Sennheiser MK300 mike apart?
download the manuals on the website of your MKE-300
Sep 21, 2010 | Sennheiser MKE-300 Consumer Microphone
Transmission distance problem on Sennheiser G2 wireless
I regularly use G2 ew100+300 systems, which have a manual squelch adjustment on the reciever. Squelch is difficult to explain but here we go: a squelch adjustment gives you the options LOW, MEDIUM, HIGH these settings effect transmission distance and interference rejection. for example: a HIGH squelch is less prone to interference but has a shorter transmittion distance. A LOW squelch is more prone to interferance but allows for a longer transmission distance. For most applications, a MID squelch is fine. If this does not help- the next option would be to swap arials between units and see if the problem moves. The G2 series are a 30mw transmittion which has an effective range of about 50m
hope this helps.
Rus.
Feb 15, 2009 | Sennheiser SK 300 G2 Wireless Bodypack...
Sockets of sennheiser hd600 broken
I've discovered the solution to the problem, I think. What has probably happened is that while wearing the head phone you have probably caught the cable any number of times on door knobs, under your heal, or perhaps around the feet of a passing dog. The cable is very long and very strong — it's Kevlar reinforced.
All this jostling has tended to bend the pins and probably the sockets they plug into. Using a delicate pair of jewelers pliers, preferably smooth-jawed, gently bend the pins outward (maybe even inward) so that they once again make a firm contact in their sockets. It's worked for me pretty well so far.
The fact that some people get no improvement from cable replacement suggests that the problem is with the internal cable sockets. The solution is still the same. I notice after doing a tweek that the plugs feel tight again.
Nov 27, 2008 | Sennheiser HD 600 Consumer Headphones
213 people viewed this question
 Grubhead
Grubhead
