Question about GE Profile Prodigy DPSR513GA Dryer
GE Profile Prodigy Electric Dryer start knob turns too far
Normally, you only have to turn the start knob about a 1/4" to the line that says start and the dryer comes on. Now, you have to turn the knob about 1/2" past the start line before it comes on.
It does come on, so not a critical problem right now, however, I am thinking it will probably stop working soon, so I want to get a jump start on potential problems and fixes. Thank you for the input.
The knob is broken and needs to be replaced.
Posted on Sep 01, 2008
SOURCE:
Dryer does not turn off, knob stays in original position
sounds like one of the keys in the tumbler is broken maybe
May 06, 2014 | GE Profile Prodigy DPSR513GA Dryer
My dryer will not start. It just makes a humming noise when I try to get it to start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE Prodigy dryer makes an electrical buzzing sound when I try to turn it on and it won't turn on.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
The dryer makes a loud squealing noise when running most of the time. Think it is a belt or bearing but cannot figure how to get inside. Top has 2 screws that cannot be reached with standard straignt screw...
Normally you would remove the front of the dryer, then it makes for easy acess of the drum and rollers..
The noise is probably your rollers, either needs lube or replacement
Sep 25, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
Washing Machine GE Profile/prodigy
you have a dry on your programmer you should not do this your self i would go down and see your local second hand shop who can help you with is they normally do jobs like that appliance shop is the best place to go it will be cheap
Dec 03, 2007 | GE Profile Prodigy WPSE4200A
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
GE Prodigy gas dryer will not start
The buzz you are hearing is most likely be caused by the motor. The motor may be stuck from a restriction or it may be faulty.
Shutting off before cycle end ? Check the vent line. It may be partially clogged.
Won't run at all ? Something may still be wrong with the wiring. Check the breakers and make sure you have 220V at the recepticle.
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
GE Profile Washer
1) Most GE appliances have service manuals. By the manual because it will save you the repair services for the life of the machine. 2) I am not familiar with the GE Profile, so I don't know if it has dial knobs, or control panels. Any way, your problems seem like the timer unit is the problem. If it has dial knobs, the timer costs about US$100 - $150. The control panel circuit probably costs that much. You can buy the service manual and parts from Sears or parts services
Aug 19, 2007 | GE Profile Prodigy WPSE4200A
Dryers Logo
285 people viewed this question
Top GE Dryers Experts
vince
gbob59
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
