Haier HPRD12XC5 Air Conditioner Logo
Posted on Jul 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Haier hprd12xc5 condensation will not evaporate
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Dec 23, 2009
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
67670
Points
282
Dear sir good day try to replace the filter or clean it up by water and air and turn on the conditioner agin thanks
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Jul 01, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
23651
Points
64
Why don't you try www.247servicecenterinfo.com, they have listing of all HAIER service centers in india.
2answers
Haier portable air conditioner has no power. How can I get to the fuse and screws do I need to remove. Model HPRD12XC5, Thank you!
there is no fuse. the manual talks about your homes power either breakers of fused. if you have breakers follow manual and call for service. page 13
https://www.appliancefactoryparts.com/content/pdfs/210565-1.pdf
2answers
WATER IS STREAMING OUT OF THE BOTTOM OF MY HAIER AC HPRD12XC5 VERY LITTLE COMES OUT OF THE DRIAN . I OPENED THE DRAIN AND A COUPLE OF OUNCES CAME OUT. MY CONCERN IS ABOUT THE WATER RUNNING ,
It is quite likely that there is a collection tray or tank for condensation inside the machine. The outlet pipe is quite likely blocked. Disconnect it from the mains (just in case) and gently push a piece of wire or stiff plastic rod (strimmer cord ?) up the pipe.
Leeking water a lot
Condensate water accumulates in the evaporator.There is a tube that drains the water out of the evaporator to the condenser side where the fan picks it up or an external drain. The tube is plugged. It needs to be cleaned out.
I have a Haier AP148DS portable ac unit. I had to replace the Condenser motor blower wheel and evaporator motor due to the old blower wheel broke. Now the evaporator motor won't turn on and I can't...
there is a start/run capacitor , did you check it to see if you have 115 vac ? also a contactor of 115 vac to check if contacts are dirty etc..
I installed a 10k haier window a/c. I really don't have a problem other than I didn't see a drain device for the unit or an escape for condensation? Model # ESA410K-L Where does the condensation...
It drains into the back of the unit and it either uses a small heater to evaporate the water, or uses the condenser coil which runs hot to evaporate the water that way. If this help please rate me and do a testimonial.
I have a haier window ac unit model hw05ca12, it doesnt appear to have a drain hole. Is this correct? Do I need to manually drill a hole in the bottom of the unit?
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
1helpful
3answers
Where is the drain hole on my haier air conditioner located
1helpful
Hi I've just purchased a used HPRD12XC5 portable air conditioner. It did not come with Air Intake/Outlet hoses, exhaust adapter or window slider kit. Is there somewhere I can buy these? Thanks -...
Harry. if you purchased it from a brick and mortar store, rather than online. Return it to the store for replacement. Or you can get it from Haier under warranty, with your Proof of Purchase. It's more to it than just the air intake and the exhaust hoses.
You can contact Haier Customer Support at 877-337-3639.
Hope this helped you. Please let me know. Thanks.
The fan is blowing water out it is not draining
fan is blowing water due to Clog Drain pipe or dirty evaporator
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
