Question about Ricoh Aficio 1035 Copier
Message SC101 Functional Problems
When i switched on my Machine it shows a red light on the upper left hand side of the panel and on the screen, it shows SC101 Functional Problems...
What could be the problem and i would be happy if someone could provide me with the solution...
  • 62 Answers
If the lamp does come on, remove the left side that holds the glass in place. It usually has the markings for where to place your origonal. Under it you will find a white strip of plastic tape, clean this. that is how it sets its lamp reference.This will usually work for a weak lamp.
Posted on Jul 07, 2008
  • WolVrine Mar 01, 2011
    thanks very much this all was veryyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
    help full
  • 42 Answers
On Ricoh's this is a exposure lamp problem.Replace lamp under platen glass.
Functional problem sc101
SC101 is an exposure problem.check if at on of the machine exposure lamp is light in a few sec. then off then follow this as a guide
SC101 D Exposure LampError At trigger on, thelamp was not detected on. Exposure lampdefective Lamp regulatordefective Exposure lampconnector defective Dirty standard whiteplate Dirty scanner mirroror scanner mirror out of position SBU board defective SBU connectordefective IPU defective
Aug 28, 2011 | Ricoh Aficio 450 Copier
Functional problem SC548-00
Try to reset the code, CLR modes key, then 1 then 0 then 7 and hold the red CLR/STOP key until your screen changes. press option 1 copy SP, then flip the red power switch on the left side of your machine. if you cant locate the switch unplug, but it is much better to use the switch
Dec 14, 2009 | Ricoh Aficio 450 Copier
Phone sceen turns on. fully charged. touch screen works. Phone doesn't turn on. Phone off displays after I have touched the on/off switch.
With the phone screen showing, press the red button at the right-hand side and hold it for about two seconds. The Centro should display a "Welcome" screen, then after a few seconds the phone screen should reappear with the carrier name at the upper left instead of "Phone Off". Each time you press and hold the red button the phone switch on/off..
Oct 26, 2009 | Palm Treo 500 Centro
Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Jan 11, 2009 | Washing Machines
IMAGE RUNNER 2200
First, turn off all power to the copier.When looking at the front of the machine, turn the machine counter clockwise so you are now looking at the left side of the machine, go to the lower left hand corner of the left side of the machine. Loosen the screw to the panel which is about 4" wide x 10" high. The screw is in the upper right hand corner. After you remove the panel, carefully slide out the toner waste container, empty it, and rinse it clean with plain water, wipe the outside clean, blow out the machine with canned air, replace waste container, put panel back on and power up your copier.
Nov 06, 2008 | Canon (6981A002AA) for imagerunner 2200,...
RESETER
THIS MACHINE SHOULD HAVE 2 ON SWITCHES. ONE ON THE UPPER RIGHT WHICH ONLY TURNS THE LIGHTS OFF TO THE CONTROL PANEL.ON THE LOWER LEFT SIDE THERE SHOULD BE A RED SWITCH THAT IS THE MAIN POWER SWITCH.THE RED SWITCH IS THE ONE THAT RESETS CODES.
Oct 24, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
Blue screen red lock
I dont have a clue what happened...
The screen is blue and has a little red lock on the upper left hand side...
remote only works to turn it on...no other buttons work.
Help please!!!
Apr 01, 2008 | Insignia IS 20" TV040919 TV
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
Ricoh Aficio 1035 Copier Logo
350 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
