Question about HP Office Equipment & Supplies
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though the problem is with the Black Cartridge), and No Cartridge present, and Clean & Reseat Cartridge. I would like a 6656A pinout reference if available. Thank You, Reggie Bostwick
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Posted on Jul 07, 2008
How To Fix HP Printer Error Code 0xc19a0043?
After installing GENUINE cartridges;
In some cases, a printer reset can clear the error message.
  1. Turn the printer on, if it is not already on.
  2. Wait until the printer is idle and silent before you continue.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    note: HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on. The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
If the issue persists, continue to the next step. Step 3: Check estimated ink levels The error might be caused by a low or empty ink cartridge. If an Ink Alert message displayed before the error occurred, replacing the ink cartridge(s) might resolve the issue.
Check your printer control panel for the Estimated Ink Levels feature. Control panel options vary by printer model. If you are unable to display the ink levels on the printer control panel, select your computer operating system below.
note: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low-ink levels, consider having a replacement ink cartridge available to avoid possible printing delays. You do not need to replace ink cartridges until print quality becomes unacceptable.
Oct 16, 2017 | HP Office Equipment & Supplies
Will the HP 2700 scan without an ink cartridge loaded? I am getting an error message about a problem with the black ink cartridge and it is overriding everything else. All I want to do is scan.
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Photosmart 2710 All-In-One InkJet...
Error OXC19a0031 Ink system failed came up while printing. Printer will not work. Never had any problem before. What do I do?
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover c00813643.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Oct 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I get a message that the ink system has failed and error message 0xc18a0001. I have turned it on and off again, also tried the suggestion on the HP web site - didn't work.
Please remove off your printer and uninstall the printer. Later reinstall the printer software and then connect the printer. Your harware- printer- will now be detected and installed into the PC. Now check and make a test print, the printer must work right now . If it is still showing an error of the Ink , use the maintenance key for ink chane before you remove the cartridge. Change and check . Good day
Aug 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
Printer cartridge problem ( Printer HP officejet 5610 All-in-One)
you need to replace color cartridge
or refill an old one if you have one
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Dec 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Incompatable Ink Cartridge HP C4480
Cartridge failed try another new one.
Yea it is new and should be good but they are machines and are prone to failure too.
Jul 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Remove and check cartridge
Replace all ink cartridges at the same time.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check color cartridge
I cleaned mine with alcohol and Q-tip and then shook it 25 times to insure that the ink was penetrating the application lines. My hunch is it first got dirty, and then dried up on the exterior prevent additional ink from leaving the cartridge.
May 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
452 people viewed this question
Ben Johnson
