Question about Pioneer PRO-710HD 64" Rear Projection Television
710 Hd Bob, Have the 710HD losing power problem.  Help. Tim. toj1@mac.com
    Scholar:
  • 90 Answers
If you are still running your set with the
intermittencies happening occasionally, TURN IT OFF NOW
AND UNPLUG IT UNTIL TIME TO REPAIR THE BOARD! If it
has shown signs of occasional malfuction and you are
still running it, you are playing Russian Roullette
with your multi-thousand dollar investment.
if you are currently using your set while it's in this
compromised condition of blue flashing, inconsistent
brightnesses, shutdowns - not only are you
risking a ground letting go on a regulation circuit,
causing your voltage to go into runaway, but
you are also risking spikes going directly downline to
the rest of your set. Hinky connections
cause spikes. There's no way to protect the rest of
your set from these spikes by installing a
surge protector on your main power plug, which is way
too far away from the circuitry concerned,
downline from the PS board, to be of any help. The PS
board has spike filtering on the incoming
120v from the wall plug, but that doesn't matter
because it delivers its results DIRECTLY to the
rest of your set, and the same filtering does not exist
at the tail end of the PS board, only at
the nose/incoming end.
If you get a new PS board, there will be a new set of
high precision voltages going downline to the rest of
your set from it. The original voltages are what the
set was set up on originally, they were sent downline
from the original power supply bd to the rest of the
circuitry, where everything was set up according to
them. Voltage regulation is generic, and only has to
wind up being within certain parameters, which means a
great deal of difference may be there among the
voltages, between the old board and the new board.
As such, I do not recommend getting a new board from
Pio for this purpose on the x10 models of Pioneer
Elite, like this one, and some of the x20 models, which
used the same PS board. I instead recommend
having the original PS board resoldered by someone who
knows the ins and outs of how to do so without creating
solder bridges in the super small connections – which
are all over that board, and in massive quantities. It
is not a job for the faint of heart, nor the
inexperienced or ill-equipped. I am the only service
repair tech I know of who is doing what needs to be
done with this board, tho some DIYers claim to have
done so as well. Others have found the board they
resoldered has gone out later, when they didn’t do it
to the level at which I do it. Boards I resolder don’t
go bad weeks, months or years later, like the original
Pio board has done. And like those resoldered by many
DIYers have done. When I resolder that board, I bring
it to the level the other boards in there are already
at - continuous non-problematic use from then on.
There are many boards in there, yet THIS one is the
only one with the problems. This was due to an
inadequate solder flow job way back when the unit was
originally produced. I cure that problem permanently.
DIYers can do it too, as long as they have the
comprehensiveness, dedication, persistence and patience
it takes to do it to the level at which it needs to be
done. Not everybody has that.
If you would like me to do the resoldering op on your
board, contact me directly and I'll send you the proper
info on how, where to send it to, and how much it
costs. Hint - it costs less than getting a new board
from Pioneer and having a local Pioneer authorized
facility install it for you.
Mr Bob
www.imageperfection.com
510-278-4247
email: bob at imageperfection dot com
Posted on Aug 01, 2008
Can I use a universal remote to adjust my settings for the elite Pro 710 HD?
I doubt it, we have in our shop about five of their remotes and each only works on one or two models--bite the bullet to get another or if you have the original but it does not work, most shops can fix that for a reasonable price.
Dec 14, 2012 | Pioneer PRO-710HD 64" Rear Projection...
My pioneer Pro-710 hd 64in keeps shutting down when turn on.
The most common problem this group of sets had was bad solder connections all over the power board that develop after some years of use----most of them I have repaired a total resolder of most or all connections on that board fixes the problem.
Dec 07, 2012 | Pioneer PRO-710HD 64" Rear Projection...
Panasonic Pro 710 HD Shuts off for no reason
Most likely bulb is dying and cooling fans are clogged with dust. The bulb iis more like a street light than a home bulb.
May 15, 2010 | Pioneer PRO-710HD 64" Rear Projection...
The convergence chip is going in my pioneee elite
Yes there are two ICs in your model they are around 20.00 each for quality ICs. Cheaper ICs are available but I wouldnt recommend them as theyre most likely the inferior chineese made ICs and they fail quickly.
Nov 27, 2009 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer PRO-710HD loosing power and now showing scrambled image
See other solutions to the intermittencies. I think your set can still be remedied by the resoldering op, especially since it still powers on successfully and stays on. I had one where the screen would stay blank while the set powered up sucessfully and stayed on, and the resoldering op resolved that problem. His set is working fine now.
Contact me for instros on how and where to send me your board.
Mr Bob
510-278-4247
Nov 08, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
510-278-4247
Oct 13, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer Elite Pro 710HD Rear-Projection Television
no reset sequence. usually when the protection kicks in without any warning, it's the convergence ICs needing replacement.
Mr Bob
Sep 16, 2008 | Televison & Video
Popping and Screen Goes Dark
I have the same power pop off on out elite 710 hd. Can you tell me what to check firts, where the board is I need to check, and what it costs to fix? Is there anyone in SC, do I need to send out? Any help would be greatly appreciated!
dorinda
May 30, 2008 | Pioneer PRO-710HD 64" Rear Projection...
HD CONVERTER FOR COMPONENT
Just Google hdmi to component....You'll find plenty of choices.
Jan 10, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Flicker in HD and DVD
The intermittencies you mention are common on this
series. The PS - power supply - board needs a
virtually complete resolder op, as the solder used in
that run of units was weak and thin. It will not get
better on its own, any more than needed dental work
will.
Send it to me and I will resolder it and send it back.
I have done so on a number of PS boards in this series,
and am running at 100% success on saving the
510/610/710 series of Pioneer Elites when all they need
is the resoldering op. There is a procedure to follow,
so contact me directly.
510-278-4247
Mr Bob
Nov 08, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer PRO-710HD 64" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
