Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
My electric lawn mower power keeps cutting out
  • phantom2222 Jul 07, 2008
    i have the same problem - the mower cuts off after a couple minutes for no apparent reason. let it rest for a minute or so and it runs fine again.
    the plastic case and handle are falling apart too, but that's another issue.
    Champion:
  • 313 Answers
Handle should be replace & the switch check if the terminal is not dis-colorization on the terminal.if any sign of dis color on the terminal then the switch shoul be replace too.
Posted on Jul 19, 2008
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
Disable all lawnmower safety switches
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
How to test lawn mower solenoid
6th How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 16, 2016 | Garden
My electric lawn mower power keeps cutting out IT RUNS WHEN PLUGGED IN BUT VERY SLOW,TIPPED OVER RUNS FAST.bLACK AND DECKER CORDED 19 INCH REARBAG
if it runs slow when mowing then when its tipped upside down there is no pressure on the blades its faster the bearing is gone worn out
Sep 25, 2008 | Black & Decker 19" Electric Lawnhog...
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
Corded electric mower loses power then comes back on during use
Same likely answer from several possibilities. Likely to be a poor electrical contact. Check *the supply had good contact for plug and an adequate fuse. *possible loose contact in the handle switch *if several years old, possible worn carbon brushes in motor. Easy to replace. *You should be using an RCD cut out switch. Check if mower works without it. Replace if dodgy
NB Only try to fix last two if you know what you are doing!
Aug 21, 2013 | Electric Lawn Mower
I cut my chord electric lawn mower
If it is a clean cut, and not all mangled up. You can get a male or female replacement plug at any hardware store to replace the cut off end. Hope this helps you.
Mar 28, 2011 | Electric Lawn Mower
Morrison 1400W electric lawn mower goes for 20 secs.
I would think that switch may be faulty? Or is it a momentary switch only?, if so, then you have an input to the controller problem, insomuch as it starts, runs, for some reason thinks there is a problem & shuts down, whereby the switch is being pressed, so it "Sees" this and starts again, and so on?
Mar 04, 2010 | Garden
My Wolf electric lawn mower will start but cuts out after 30 seconds then after some minutes will start aagin. Have checked power is getting to motor and is fine. Also put multimeter across motor &...
There may be a fault contact due to vibration check all the electrical wires and contacts if they are very well connected check corrosion point at contacts, use wd40 spray oil in the motor and contacts, there may be a fault in the carbon contacts to the rotor.
Hope it help
Jun 25, 2009 | Electric Lawn Mower
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
219 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
