My goodman heat pump has frozen up 3-4 times already this summer. It is a dual system 10 seer (i believe are the terms). Every time someone comes out they can't figure it out because the system is running fine by the time that they come. Two years ago the blower or activator was replaced (maybe the replacement part isn't so good?) The unit is 9 years old. Last year a guy charged it and about a month ago when it was checked the freon was only a little low. I'm SO tired of this issue. Any ideas?
  • Anonymous Mar 14, 2014
    Every now and then our airconditioner which is a Agean brand that was installed around 10 years ago , up an till the last 1month we have never had an issue with , all I need to do is switch it of at the iscolater and all is good have you any idea what the error code E4
    Scholar:
  • 104 Answers
After system has been running 10-15 minutes, the discharge air temp should be 18-22 degrees colder than the air being sucked in. If the air is more than 22 degrees colder then the problem is with air flow. Check filters, blower speed, make sure all vents are open, is indoor coil clean. If the discharge temperature is less than 18 colder, then the problem is with the refrigerant portion of the system (low charge, improper flow control of freon into coil) the key is if you have an orfice or a TXV (Thermal Expansion Valve) to control the flow of refrigerant into the coil. TXV's are known to fail with intermittant problems, however, most 10 seer systems do not use a TXV, they use and orfice which could have debris in it affecting the flow of freon. Hope this helps. When you rate my solution, please keep in mind that I am a technician that normally diagnoses equipment by checking it out in person. I do the best that I can with the information that you provide me on Fix-Ya.
Thank You,
Chillmaster
Posted on Jul 07, 2008
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
I installed my new unit this summer and the ac worked fine, now the heater does not work
frist check that the thermostat and the mood is in right positions then check that thermostat give signal to Htr.if Htr is right ohms
Nov 11, 2013 | Goodman Manufacturing Goodman...
I have a leak
Under warranty from 10 years ago??
I would get it repaired properly by a qualified service engineer after speaking to the manufacturer.
Nov 16, 2017 | Goodman GPH1536M41 3 Ton 15 SEER...
We have a Goodman CKL 3.5 ton 10 seer AC unit. it is labeled Amana Distinction. it is installed in 2006. CKL 42-1L. The problem is that when the wall thermo control kicks on, the fan blows 3 minute of...
Yes there is a way. First You need to see if the outdoor unit has a time delay on it.It would be connected to the contactor and the low voltage wires. If there is not one then there is a problem with your thermostat. If you have the thermostat manual, check to see if there is way to change from the 3 minutes to none. I hope this helps you.
Jun 05, 2011 | Goodman CKL24AR24 Air Conditioner
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
3ton heat pump googman 14 seer
Give me the model numbers on the heat pump and the coil, I would expect its a really poor match.
Nov 11, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
