Question about Ruud UBHC Air Conditioner
REST BUTTON ON RUDD AC
CAN YOU TELL ME WHERE REST BUTTON IS LOCATED?
  • Anonymous Jul 08, 2008
    THE 2 FAN WILL NOT COME ON OUTSIDE OR INSIDE AND I HAVE TRIED THE BREAKERS BUT NO LUCK THE FAN CAME ON WHEN I HAD IT ON MANUEL BUT WHEN I SWITCH IT TO AUTOMACTIC THEY WOULD NOT COME ON ANY MORE
  • 828 Answers
There is no reset button. Check your main power panel for the circuit breaker. Check the fuses in the outside disconnect if it has fuses. Some only have a reversible block.
Posted on Jul 07, 2008
Where is the emergency gas shut off rest button located on a 97 civic
Right next to the emergency gas shut off button. Lol
Dec 15, 2016 | Cars & Trucks
Clock not working how do I reset it?
If rest of controls work here is how to set clock. Press clock button, enter correct time, It may ask for AM or PM and tell you to press a button to select. Then press either start or clock again. It may actually tell you which one to press to finish Depends on which model you have.
Mar 31, 2015 | GE Microwave Ovens
How do i unlock my htc after many pattrn attepts
What type of HTC phone EVO Incredible? I suggest a hard rest as you cannot get into the phones menus. A hard rest will put you back to factory status you will lose all your pictures,music,data,etc.
To perform a hard reset using the device keys:
  1. Turn off your phone
  2. Press and hold the volume down button (located on the right side panel), and then press the Power button
  3. When the display turns on, release the volume down button
  4. Use the volume buttons to select CLEAR STORAGE, and then press the Power button
  5. All data will be deleted from your phone Your phone might be slightly different but try this
Feb 27, 2015 | HTC Desire HD A9191 Smartphone Unlocked
4.3" android tablet
My tablet wouldn't turn on, so I pushed the rest button that is located on the outside of the tablet. the screen come up with a pin code that is four numbers. it never had a lock on it, until I pushed the reset. I can't get in to the tablet. what do I do?
Aug 02, 2013 | Polaroid 4.3" Internet Tablet
Transmission fuse blown
It will be located with the rest of the fuses. Fuse blocks can be in more than one location so check manual for all locations. Manual should tell you which fuse is for the transmission.
Jan 15, 2013 | 1990 Nissan 300ZX
Is the condensate outlet tube threaded on a rudd ac air handler
Hello, the fitting that attaches to the condensate pan is threaded. The rest of the line is just slip fittings.
Jun 13, 2012 | Heating & Cooling
I have a 6 year old Rudd heat pump.The AC would run for a while and the compressor would shut down until I pushed the reset button.An AC contractor came out and looked at the unit and bypassed the reset...
The reset button that he is talking about is probally the high pressure manual reset. There are reasons that this can trip.
1. Dirty condensor. 2. Condensor fan motor not up to par. 3. A liquid line dryer that is partially blocked. 4. A metering device that is not feeding right. If he verified all these and it still tripped maybe a bad switch. Anyways, with it bypassed what ever problem that is causing it to trip is still there and will get worse and the compressor will burn up and he will come and put in a brand that he likes. Hope this helps.
Jun 01, 2011 | Heating & Cooling
Power failure unit went off of a rudd split unit
If he reset it on the outdoor unit, this could be a high
pressure switch located where the compressor is, which is attached to the refrigerant line.
Make sure your indoor unit operates by putting the fan to manual, if it operates your problem is not there.
Make sure your breakers have not tripped which should be located in an electrical panel in the house
Jun 28, 2010 | Ruud UAKA030 Air Conditioner
How to rest oil change/tire
In the fuse panel located by the drivers side door on the dash is a red rest button.Push that button until the desired light starts flashing oil/tire pressure.Once the light starts flashing hold the reset down for about 10 seconds this should reset the light.
Jun 03, 2010 | 2001 Pontiac Grand Am SE
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
Ruud UBHC Air Conditioner Logo
369 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
