Question about LG LSC26905TT Side by Side Refrigerator
Ice maker the ice maker on our LG refrigerator use to over flow with ice. Now it won't even fill up the bin. Why?
  • chestercc1 Oct 18, 2008
    we have a side by side ( GR L 247 STB ) that struggles to fill the bin. ice cubes are frozen in the tray but wont drop down into the bin. the fridge /freezer is just over 1.5 years old any help would be appreciated. thanks
  • mark435 Dec 29, 2008
    My LG Ice maker fridge has a similar problem but it seems to be due to it not filling the ice tray with enough water, it seems to only fill half the tray. I changed the filter but still no joy, is there an adjustment somewhere for how much water it pours into the tray?
    Problem Solver:
  • 10 Answers
Pammytrent:
The icemaker only harvests / drops once the icemaker get to a temperature of Approx 15 Degrees.
Most manufactures Icemakers make approx 70 icecubes in a 24 period .
This can depend upon ambeint temp, use of product [opening closing of doors.
You will need to make sure the your condenser coil under the unit is clean.
Before cleaning disconnect power to unit first.
Air flow curculation in freezer can effect production also . too much food can restricting air flow, to little in freezer can effect ice production too .
hoping this helps
woodychoppers
Posted on Nov 01, 2008
How do I fix my LG icemaker
It usually costs more in labor and parts to repair an ice maker.
I suggest swap it out with a new one.
Nov 02, 2017 | LG Refrigerators
Why the ice tray does not drop the ice into the bin?
Maybe you forgot to drop the sensor bail back into the bin.
Jan 23, 2018 | LG Refrigerators
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Ice maker leaking after filling
Most likely the=> 67005154 Dual Waater Control Valve
found on the rear of your refrigerator and down near the floor is becoming worn out and not closing all the way. Are the ice cubes also beginning to stick together? I need you to watch this problem to see if it becomes worse and gets stuck open allowing a lot of water into ice maker. The ice maker determines how much water flows to ice maker about 7 seconds time but if mechanically defective it will not close all the way even when off. I will stick with a solution but will meed you to respond, Thank You, Sea Breeze
Dec 10, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Lg lsc26905tt ice maker makes ice, but wont turn dispenser
you can look to see if something from the freezer dropped into the chute? it may have blocked the exit. Is this all new ice or has it been a while since you used it? Maybe the auger in the bin is stuck?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
289 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
