When i connected usb cable to computer it sparked now printer wont even turn on
IF you got a spark sounds like the printer is shorted out, you will need to replace it or at least take it in for service
Posted on Jul 07, 2008
It's Kodak ESP 7 all in one printer I need it to connect to computer and it's even directly connected and it still wont
etHard to see on your video, but the blue cable - is that the one you are using to connect your printer to your computer? That looks very much like a network cable. Is that correct?
To connect the printer directly, you have to use a USB cable. If you use an Ethernet cable, the printer has to be plugged into your router or switch, or it will not get an IP address. Check the user guide here: http://resources.kodak.com/support/pdf/en/manuals/AiOPrinters/ESP7/1K3397_SETUP_BOOKLET_ESP7_en.pdf
What does your setup at home look like? - Router, Computer (OS), wired/wireless?
If you need more help, let me know and please provide some details.
Jan 03, 2013 | Office Equipment & Supplies
Hp 5500 keeps saying cannot communicate with computer?
You can try to:
- Turn the printer off then turn it back on - Unplug and replug both ends of the usb cable connecting your printer and computer - Turn off the firewall - Reinstall the printer driver and software - if it still wont work, try a different usb cable
Dec 31, 2010 | HP Photosmart C6180 All-In-One InkJet...
It says HP psc1315 printer is offline and won't print. how do i fix? wont change back to online also one document at front of queue wont delete
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
Jun 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
Dont know how to work print to cd/dvd on my hp printer c2580
First check your usb cable of your rpinter to computer connected proeprly and working fine.
try another usb port of computer.
Then if you cant get print then uninstall driver then reinstall it.
you can downlaod your driver from this likn if you haven't.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3204463&lang=en&cc=us&prodTypeId=18972&prodSeriesId=3204462&taskId=135
Aug 20, 2009 | HP Photosmart C5280 InkJet Printer
Wont prit
reboot the computer and the printer..
then try to do a "Print Test Page"..if it still does not print, turn off the computer again, unplug the printer from the back of the computer ( I assume it's connected via USB), then plug the printer on a different usb slot on the computer.. you may have to re-install the drivers. make sure you have the cd for the printer.
Hope this helps.
May 09, 2009 | HP DeskJet 840c InkJet Printer
'Communication Not Available' message when printer cable connect
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Nov 18, 2008 | Lexmark X2250 All-In-One InkJet Printer
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
CHARCOIS
Oct 17, 2008 | HP Office Equipment & Supplies
Can't connect my printer to computer
HI-
What do you mean by you can't connect it? do you have a USB cable still? for the software/ driver you can download it from support.epson.com site or www.epson.com then go to drivers and support and select your printer model and choose drivers and download for your operating system. then connect usb cable when it prompts you during the installation process.
Hope this help
Sep 24, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Printer causes Flash Drive and Ipod to not work
Ipods and the Kodak printer are both high power devices. There are known issues on common intel motherboards with multiple high power usb devices. You may just have this bad luck, and your motherboad printer ipod combo just wont work at the same time. The best advice I can offer you is to get a High Speed Powerd USB hub. Connect either the IPOD or the printer to the hub and connect the other directly to a USB port on the PC.
Good Luck!
Jan 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
47 people viewed this question
jasbo
jasbo
