Question about Singer Quantum XL-6000 Computerized Sewing Machine
SOURCE: singer Futura CE100 Embroidery
check to be sure machine is being threaded correctly first, then when pressure foot is lowered pull thread and see if you are getting tension, if not assembly is bad
Posted on Jan 21, 2008
SOURCE: Hi, I'm trying to embroider
The plastic drop-in bobbin case, is the worst I have ever seen. The thread will get jammed in it or it hops while the machine is sewing. It is not staying in place. In front of the case, on the right there is a tiny, rectangle spring. It is the only thing I can find that keeps it in place. It is attached with a tiny screw and can be moved forward.
Posted on Sep 06, 2009
SOURCE: I have a singer embroidery xl5000 machine. It will
Try removing the bobbin and cleaning the area of any stray threads or lint. When you replace the bobbin pull on the thread. The thread should pull easily and smoothly.If the bobbin is dirty inside the thread will get stuck and bobbin will get **** and thread will break.-------Check out. Thanks.Helpmech.
Posted on Dec 29, 2010
SOURCE: My bobbin thread keeps coming to the top of my
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Posted on Apr 24, 2011
SOURCE: polyester thread fuzzing on my 328k singer. using an 18 needle on marine vinyl
try changing the needle--just incase the needle tip is damaged
check for burrs in the thread guide area where the top thread runs
or even on the needle plate
Posted on Jun 06, 2012
Jan 10, 2016 | Singer Quantum XL-5000 Computerized Sewing...
Jul 15, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Jan 01, 2014 | Singer 5050 Mechanical Sewing Machine
Sep 27, 2012 | Singer Quantum XL-6000 Computerized Sewing...
May 01, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Oct 07, 2011 | Singer CE-200 Quantum Futura Computerized...
Apr 30, 2010 | Singer Quantum XL-6000 Computerized Sewing...
Jan 06, 2009 | Singer Quantum XL-6000 Computerized Sewing...
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Nov 06, 2007 | Singer CE-200 Quantum Futura Computerized...
52 people viewed this question
