Question about Gateway Computers & Internet
Laptop touchpad no longer does tap function
I know this is a simple fix but it is extremely annoying at the moment. I need to be able to restore the tap to enter function on my touchpad. I have tried to look in the control panel-mouse functions and I don't see anything on the touchpad in there.
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Posted on Oct 09, 2008
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Touchpad not fully functioning
go to add remove hardware
check out there input device uninstall it and then click on search link or refresh it will solve ur problem
Jan 13, 2013 | Acer Aspire 5742 Notebook
I need tp know how to unlock my touchpad for my Presario CQ62 laptop
Hi lilzett14...
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using a Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 16, 2011 | Computers & Internet
Touchpad sensitivity: hi there, the sensitivity on my uncles HP Compaq 6720s is extreme, you can literally drop a feather on the pad and it clicks like you were tapping it, this gets extremely annoying...
GO TO CONTROL PANEL.SELECT KEYBOARD.RIGHT CLICK IT AND SELECT PROPERTIES.FROM THERE YOU CAN SET YOUR OWN PARAMETERS.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | HP Compaq 6720s Notebook
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
Tap function in my laptop not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
Select software and drivers
Mar 27, 2009 | Computers & Internet
Toshiba A105-touchpad mouse intermintent problem
If you know where the touchpad/mouse driver is located on a recovery disk, I would 'delete' the mouse via the control Panel, reboot and see if Win will reinstall the driver from the restore partition or, ask for a disk as a source and you have to know where that driver is on the optical disk. I would locate the drivers on your recovery disks before you delete the current device.
Alternately, you might check Toshiba's support section for a touchpad driver for your OS and system and burn it onto a removable disk or thumb drive that you give to Win as a destination if asked.
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Laptop touch pad doesn't work properly
Here is what I did to get the touchpad to start working again. My laptop is Gateway and a couple years old, running Windows Vista.
1. Start>Control Panel
2. Double-click on Mouse icon (or button, depending on how you're systems set up).
3. When a the Mouse Properties window pops up, choose the Device Settings tab.
4. Click on the Settings... button.
5. A new window pops up and on the right side there is a list of options - choose Tapping.
6. Once clicked, there is a check box that allows you to Enable Tapping.
7. Click OK to close out your windows and the tapping option should be enabled on your touchpad.
Hopefully this helps.
Dec 29, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
536 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
