Canon MP530 Printer Error 6B10 will not reset after first page printed fine.
  • 1 more comment
  • Anonymous Sep 14, 2008
    not reset
  • 2416 Apr 11, 2009
    code 6b10
  • supernew May 21, 2009
    Error 6B10 occurs when the paper feeder from the bottom is not working. Any advice on how to fix this problem?
  • 159 Answers
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
old marine
  • 2036 Answers
SOURCE: Printing a book from Word using duplex printing
In the Printing Preferences window, on the Page Setup tab, you have already selected Duplex Printing and Automatic. If your book is to be bound on the long side, you should have 'Long-side stapling . . ' selected in the window below that.
If that is what you have selected and the pages are printing wrong, try the 'Short-side stapling . . .' option.
Posted on May 09, 2008
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
AFter we tried everything, the paper we bought was apparently not quality controlled and mixed with different weights of paper that caused the error. We purchased another brand and have had no problems so far...
Posted on Dec 02, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Posted on Dec 27, 2008
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
My MP530 won't print. It isn't coming up with an error and all the inks are fine.
I know this sounds rather patronising but are you sure you have removed the tape on the black in cartridge before you fitted a new one. You would be amazed how many people forget to do it.
Jun 27, 2014 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 multifunction printer
HI,
1.Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
Sep 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 28, 2011 | Canon PIXMA MP530 All-In-One InkJet...
MP530: After printing one page, it gives "Paper Jam" error, I open and close the ink cover, and print another page, with the resultant "Paper Jam" error, etc. Any solutions?
Either you have a bad sensor, or the sensor arm is bent so that it doesn't return properly after paper passes thru, It's hard to see, on the right side behind the platen roller, above the white guide plates.
Aug 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5C10
From Canon. Issue: ERROR LCD: Error Code 5C10
1. Press ON/OFF switch to reset the multifunction device 2. The MP530 may require repairI would remove the print head and inks,unplug it completely from thr eall for a half hour.Plug it back in and install everything.
Jun 17, 2009 | Canon PIXMA MP530 All-In-One InkJet...
6B10 problem
If you still need the user guide, you may find it here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12804
I'm afraid that here is already a mechanical problem on your printer if displays 6B10. It's a paper feed sensor error on your printer that means you need to have it serviced with an authorized canon technician.
Hope this helps.
Thanks.
Jul 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP530
it may need to be reset or the worse the power surge blew out its memmory chips inside the printer. printers come with an amount of memmory about 4 to 8 megs so that it can remember print jobs try a test page after you leave unpluged for half hour
the printer should be able reset itself
May 04, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
917 people viewed this question
jasbo
jasbo
