Question about KDS Radius RAD-7 17" Flat Panel LCD Monitor
Monitor stays black
I have KDS K717 monitor model no 700P when I turn on the screen just stays black eventhough the power indicator light says that it is getting power. Is it shot? Do I need to buy a new one or can this one be fixed with out a lot of expense.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • KDS Master
  • 848 Answers
Monitor stays black? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 170DTLAPH PI 170DTLA 200 000 170DTLA AH 860 AB0 170DTLAPH Power...
Posted on Jan 03, 2015
    Novelist:
    Scholar:
  • 141 Answers
First make sure you have the monitor cables correct. Try another monitor hopefully works so you can go into your device manager and make sure the right drivers are loaded and that your monitor is listed. You may do some research because I'm not sure but I think your monitor uses a back light & an inverter which is replaceable and not usually a difficult job or to expensive. Labor of coarse cost more than the parts. Monitors use a video card or on board video so make sure these are not the problem.
Are you sure its not in wake mode in the bios?
If you shine a light on the monitor when the comp. is on and the monitor light is on you may be able to see your screen. That would be the back light.
When if all and what was going on when it stopped working?
Posted on Jul 07, 2008
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
Kds k717 screen is black what is wrong with it
The same problem happend on mine it was ac power converter box had to replace it twice but its been working for 3 years now note light was on both times
Nov 10, 2009 | KDS K717s 17" LCD Monitor
After 15min the monitor cuts off. KDS k717. Iturn it off for a few min and turn it back on and it does it again
power converter/supply bad defect contact manufactuer and ask for warrenty replacement
Mar 13, 2009 | KDS K717s 17" LCD Monitor
Monitor does not want to come on
Twelve years is a lifetime for a monitor.
May 15, 2017 | KDS 17S 17" Monitor
KDS usa flat screen monitor model 780 2003
Shine a light on the screen and see if the Icons are there.. Could be a CCFL bad or inverter problem..
Jan 25, 2008 | Gateway FPD2275W LCD Monitor
KDS Radius RAD-7 17" Flat Panel LCD Monitor Logo
229 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
