Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet Sport Front Load - Spin Cycle Noise
My Duet Sport is making a horrible clanking noise on the spin cycle. I suspect some change or a button or something has worked its way between the drum and the housing. I have removed the top cover and can't see anything obvious that might be causing the noise. How do I open it up to find the source? I don't want to remove more parts than I have to!
  • Craig2055 Aug 22, 2008
    I have the exact same problem with my washer. The drum inside almost looks like it is loose because it is moving back and forth as well as spinning. Making a horrible racket in the rince/ spin cycle. Not sure of the model number but I know it is a front loading whirlpool duet that I bought in 2001. Just started making the racket recently. Going to go around back and see if anything is loose when I get home from work today. Don't really think the offered solution is my problem because it has been working fine for years.
I had the same problem but I was able to fix, by adding some rubber to the drain hose clamps located on top of the electronics box inside the back on the bottom left. No more noise!
Hope this helps!!
Posted on Jan 13, 2010
Had one do this. Turn machine around look at bottom two corners. Machine comes with metal rods to stabilize drum during shipping. Installer forgot to pull those out on mine. Once I removed them noise quit.
Posted on Aug 11, 2008
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Funny noise in spin cycle
u will change the drum belt. ask service people to change ur belt.
Mar 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
No spin cycle on Whirlpool duet model ghw9100
If front loader, take top off (dissconnect plug) check the beltmay be broken- the motor may be spinning on its own
Also spin the drum round to make it has'nt seized
Jul 22, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Dec 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Noise at the end of spin cycle
possible bearing going out in your barrel.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
1,138 people viewed this question
Dan Webster
Dan Webster
Sal De
