I have a set of JBL JRX125 (s) and the high end won't work on them. Not sure if I blew a fuse or the cone or what. The only audio I can get to come through them is low end.
  • 1,512 Answers
Hi hoit
They will have either blown high frequency compression driver, or the lamp mounted to the crossover board has failed. Best way to check is pull the horn flare out of the speaker box, and check the voice coil of the HF driver(JBL2412). I think they are 8 ohms from memory. If they are shorted, or more likely open circuit then this is you problem. If they appear ok, then check the lamps. The lamps are there to protect the horns from being overdriven, odd lucks means I have seen it work the other way.
If the JBL part is too pricey for you (they are for me), you can get aftermarket replacements from many places for about $40 each. It is a replacement diaphragm that you need for each HF driver.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 07, 2008
I have to replace a sub in a jbl encounter and the wiring is yellow and orange. Which is pos, and which is neg?
Use a C or D size battery. Get two pieces of wire. Strip each end. Wire one end of each to the sub. The other ends you will place one on the top of the battery and, one on the bottom of the battery. If the cone moves outward, you have the correct polarity. If the cone moves inward(toward the back of the speaker) then you have the polarity backwards
Jun 28, 2015 | JBL Car Audio & Video
I have a set of JBL Creature Speakers that I take good care of. However, one day, I knocked one of the satellite speakers off my coffee table, and subsequently that speaker only plays very faintly,...
Without seeing it it is hard to tell, but it could be that the speaker cone is out of the magnet hole, and is missaligned, in other words the voice coil could be sitting on top of the magnet instead of in the magnet hole... If you DELICATELY push on the speaker cone does it move in and out???
side view cut away of a speaker...
Aug 20, 2011 | JBL CREATURE II Computer Speakers
Bought the stereo 6 months ago, now the speakers won't work!!!! Please help!
Hi, when a speaker does not work, you might need to do some troubleshooting tips to know exactly where the problem is .
First you will need to test the speaker cone if it's working properly by using an AA battery and two wires to make sure the cone is working..
Connect one of the wires to the Positive side of the speaker, and the other on the Negative side, And after that use the battery to hear if the speaker cone will make a click sound.
If it doesn't make a click, that means the speaker cone is Bad, you will need to replace the speaker cone,
But if there is click from the speaker cone, that means the speaker is Ok, and you might need to trouble shoot your stereo to be sure if the sound IC chip is Ok in the stereo..
Hope it helped..
Aug 10, 2011 | Audio Players & Recorders
JRX125...there was a rattle/noise that indicated blown driver on midrange horn...replaced drivers, noise still occurs. discovered loose 1/4 in jack to tip of plug...tightened fit, but didn't trust...
The noise MIGHT be a resonance in the cabinet. The way to find out is to sweep a frequency upward to see if something rattles at certain frequencies... Don't be surprised to find several. Within the cabinet are the usual culprits: Wires rattling against the cabinet, loose debris, grilles and the logos on them, circuit boards with crossover hardware, cabinet wood that is not glued and rattles against itself. Things like bass port tubes can rattle.
Find an audio generator and sweep the cabinet from 50Hz to 10KHz and you will be surprised. Some speakers may have resonances as well. Expect things in your room to start rattling as well.
This is really the only way to find the problem. PLEASE wear hearing protectors at levels above 90Db.
Mar 27, 2011 | JBL New Jbl Jrx 125 Dbl 15 2 Way Speaker...
REPAIR CONE TEAR IN 18"
If the tear is large, or the speaker cone is brittle because of age, you might be best off having the speaker completely reconed. There are companies that offer the service, or you can buy replacement cones and do it yourself.
For small tears (an inch or so long), you can glue a patch in place. I have used a piece of a paper coffee filter as a patch, and plain white Elmer's glue slightly thinned with water. Put the patch over the tear and use a small brush to spread a thin layer of glue over it. Give it a day to thoroughly dry and you should be set.
I have found this repair to be more effective on smaller speakers than on large woofers, though. The woofer cones are more mechanically active. But I patched a couple of 15-inch cones that had been punctured for a friend, and they are still playing after a year. So it can't hurt to try.
Jan 30, 2011 | Audio Players & Recorders
JBL EON15 PA Speaker problem
check the wire terminals under the cone by the spider and make sure that they are both still connected
Apr 16, 2009 | JBL GTO Series RLC Amplifier Accessory -...
Jbl 15" sub
umm. i think you having some driver problems. how many watts you put it? do you have a filter? if you have one install it or turn it on. lets see what happends.
Nov 10, 2008 | JBL GTO1202D Car Subwoofer
Old Speaks
if u r little idea u can fix it
by using sinthetic rubber based gum (like fevicol sr) and glue it.
Dec 30, 2007 | JBL CREATURE II Computer Speakers
103 people viewed this question
 Grubhead
Grubhead
