I agree with Joanne. Just replace it! Safest thing to do.
First, call a master who understands ovens. Maybe he can fix it. You should not try to repair it yourself, as it is likely to make it worse. If this does not help, then it will be easier to buy a new oven already. In this way, many problems can be avoided. To be honest, I have never encountered problems with household appliances after moving to new homes. I usually use services that provide a full home inspection before buying it. https://www.thinspect.com.au/ is a good example. I hope you can solve your problem. But still, I highly recommend that you just buy a new oven, so you can save a lot of time.
SOURCE: Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
SOURCE: Oven is pouring smoke out of the top when it is
change your control switch...........bsc appliances 07779933829
